Loose motor mount screws
Old Aug 13, 2004 | 09:56 AM
Cancelled this name's Avatar
Default Loose motor mount screws
i was just wondering if this was a common problem among theses cars w/ swapped engines because it has happened to my b/f's hatch and his bro's CRX..
Yesterday my b/f was driving and he felt the car driving wierd so he pulled over to check his engine and all 3 screws popped out of the engine so he got it towed home...
Before that happened only one screw was loose and he was going to get it fixed ..
my other question is even if he gets it fixed whats the possibility that it will happen again? should he just get a new Block?
well thanks for the help
Modified by xxxVtecChickxxx at 11:22 AM 8/13/2004
Old Aug 13, 2004 | 10:02 AM
Keebler's Avatar
Default Re: Loose motor mount screws (xxxVtecChickxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxxVtecChickxxx &raquo;</TD></TR><TR><TD CLASS="quote">
What?
Maybe he should be posting questions concerning his own engine...
I would venture to say they arent screws, but bolts... Either way, you need to clarify wtf you are talking about.
And why on Gods green earth would you need a new engine?
Old Aug 13, 2004 | 10:13 AM
Default Re: Loose motor mount screws (Keebler)
He duzn't post cuz he HATES this site... I just figured some ppl w/ the same kind of cars might have had the same problem where the "bolts" start to pull out and it like grinds the frkn holes where they go SHEESH!! why the frk do u have to be such a jerk? If u don't have any advice and want to talk crud then don't post ..... don't waste both our time
Old Aug 13, 2004 | 11:35 AM
EP3_05's Avatar
So you are saying the bolts stripped the threads out of the block?? If so I would figure out why they pulled out and fix that first before fixing the block by retapping or helicoiling the threaded holes. From what I have seen this is not a common problem but it does happen. I had a bolt back out of the mount that goes through the rear bushing on my hasport rear mount. So bolts backing out on swapped cars does happen due to the vibration caused by the stiff mounts. Also another suggestion, make sure all the bolts are torqued properly.
Old Aug 13, 2004 | 11:49 AM
Keebler's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxxVtecChickxxx &raquo;</TD></TR><TR><TD CLASS="quote">He duzn't post cuz he HATES this site... I just figured some ppl w/ the same kind of cars might have had the same problem where the "bolts" start to pull out and it like grinds the frkn holes where they go SHEESH!! why the frk do u have to be such a jerk? If u don't have any advice and want to talk crud then don't post ..... don't waste both our time </TD></TR></TABLE>
Dont waste our time by posting retarded, misinformed questions
Old Aug 13, 2004 | 11:51 AM
kid-honda's Avatar
The motor mount bolts?
If you properly tighten the bolts they aont come out.
Old Aug 13, 2004 | 12:05 PM
HatchBox's Avatar
Skoobie no more...
Default Re: (kid-honda)
if all 3 bolts came out,,,, wouldnt the engine fall out?
you need to clearify your posts. just my .02
Old Aug 13, 2004 | 12:15 PM
kid-honda's Avatar
Default Re: (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">if all 3 bolts came out,,,, wouldnt the engine fall out?
you need to clearify your posts. just my .02 </TD></TR></TABLE>
Thats what I was thinking but who the hell knows what she is asking and we cant see the car.
Old Aug 13, 2004 | 01:11 PM
Fobtions's Avatar
im thinking shes talking about the timing belt side mount, when they are stripped or improperly torqued. the motor falls and rests on the radius arm.
Old Aug 14, 2004 | 07:56 AM
Yes all 3 came out and No, the engine didn't fall out, it's just sort of hanging there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fobtions &raquo;</TD></TR><TR><TD CLASS="quote">im thinking shes talking about the timing belt side mount, when they are stripped or improperly torqued. the motor falls and rests on the radius arm.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keebler &raquo;</TD></TR><TR><TD CLASS="quote">
Dont waste our time by posting retarded, misinformed questions </TD></TR></TABLE>
it's nice to know there are forums where people go out of their way to be a jerk about something then to just tell me i needed more info.. to these types of people..God will deal with them
to those who arent like that
Old Aug 14, 2004 | 12:25 PM
Keebler's Avatar
Default Re: (xxxVtecChickxxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xxxVtecChickxxx &raquo;</TD></TR><TR><TD CLASS="quote">Yes all 3 came out and No, the engine didn't fall out, it's just sort of hanging there
to those who arent like that </TD></TR></TABLE>
GBRacing
34
Feb 3, 2010 12:03 AM
ef0cmacro
Aug 23, 2006 08:13 PM
Cee_mon
Jun 11, 2006 12:13 PM
hamadiscool
May 24, 2006 01:08 PM
Loveless
Jan 4, 2004 04:25 PM
