SIR-G Swap
Old Aug 12, 2004 | 01:06 PM
98JDM_Type_R's Avatar
Default SIR-G Swap
What do I need to complete the swap into a 99-00 EK. The motor is coming out of an EG.
Old Aug 15, 2004 | 10:16 AM
Default Re: SIR-G Swap (98JDM_Type_R)
Okay, I already got the driver side mount & rear tranny mount. Do I need to change the wire harness? I'm going to be using a OBD1 P72 ECU.
Old Aug 15, 2004 | 05:11 PM
VTECVillain's Avatar
You'll need to get an OBD2B to OBD1 ECU adapter harness to use the OBD1 P72 and then add the necessary wiring for the added sesors. If you can get a 99-00 Si harness it will be more plug and play but any other 99-00 EK harness will work with only a few changes and added wires.
Old Aug 15, 2004 | 06:51 PM
Jules Winnfield's Avatar
might find some additional info in here: https://honda-tech.com/zerothread?id=650230
Old Aug 15, 2004 | 09:52 PM
Default Re: SIR-G Swap (89cr-ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89cr-ls &raquo;</TD></TR><TR><TD CLASS="quote">might find some additional info in here: https://honda-tech.com/zerothread?id=650230</TD></TR></TABLE>
I've already read those posts, but they only cover obd2 to obd2 swaps. They don't talk about obd2 to obd1 swaps.
Old Aug 15, 2004 | 10:12 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98JDM_Type_R &raquo;</TD></TR><TR><TD CLASS="quote">
I've already read those posts, but they only cover obd2 to obd2 swaps. They don't talk about obd2 to obd1 swaps.</TD></TR></TABLE>
, i didn't really read all of them...just figured they might have some useful info. well try searching and maybe: http://tech.hybridgarage.com/
johnnys_ek9
Nov 29, 2006 08:15 PM
DFW
May 2, 2006 07:44 PM
DFW
Apr 30, 2006 07:37 PM
92eg6
12
Jun 3, 2004 11:52 AM
StreetRacnGsR
May 10, 2003 06:24 PM
