Converting OBD2 to OBD1 ek
Re: Converting OBD2 to OBD1 ek (johnnys_ek9)
Well this depends on what swap you are putting in your obd2 car but it is pretty easy anyways. If you're going to be using a vtec engine and your car didn't come with vtec then your original harness has to be wired for vtec and a few sensor wires have to be lengthened. As far as converting from obd2 to obd1 just use a jumper harness that plugs into your harness where your computer would go then your computer would plug into the jumper harness but make sure you have the right jumper harness for your car. 96-98 ek would use a obd2a to obd1 harness and 99-00 ek uses obd2b to obd1 harness.
in my 2000 si:
si engine harness
si fuel rail and injectors
si trans
skunk2 im
obd2b-obd1 jumper harness
gsr obd1 ecu
gsr obd1 longblock
runs perfect with no cels at all...
si engine harness
si trans
skunk2 im
gsr obd1 ecu
gsr obd1 longblock
vtecftw
08-11-2007 11:15 AM
danxdan
06-09-2005 04:46 PM
FritzInTN
07-10-2004 09:45 AM
