Clutch Pedal ?
Old Aug 11, 2004 | 12:32 PM
civiceg500's Avatar
Default Clutch Pedal ?
I just rebuilt my engine and added a new clutch back in December. I recently have been experiencing problems with the clutch pedal. When i start my car, the clutch pedal just sinks to the floor like it has no hydrolic fluid in it and after a few pumps, it feels normal again. Could it be the clutch, clutch master cylinder or air in the lines? Any advice?
Old Aug 11, 2004 | 01:07 PM
Syner-G-Racing LLC's Avatar
Default Re: Clutch Pedal ? (civiceg500)
I would suggest you bleed the lines, it sounds like air in the lines. if that doesent fix it then you may want to check for leaks related to the master cylinder, maybe a rebuild is in question.
Old Aug 11, 2004 | 01:26 PM
mnbv's Avatar
Default Re: Clutch Pedal ? (Syner-G-Racing)
good advice right there.
Old Aug 11, 2004 | 02:02 PM
IVI's Avatar
IVI
Default Re: Clutch Pedal ? (mnbv)
check for fluid leaks under your clutch pedal and by the clutch fluid reservoir, and also near the slave cylinder in front of the car.
Old Aug 11, 2004 | 08:29 PM
civiceg500's Avatar
Default Re: Clutch Pedal ? (IVI)
I have determined that there is a very slow leak coming from the master cylinder. That will let the air in. Should i buy a new master cylinder or can i have it rebuilt or change the seals.
Old Aug 11, 2004 | 08:45 PM
Andres-eh2's Avatar
the master cylinder is for brakes.
You either need a clutch fluid reservoir or slave cylinder
Old Aug 11, 2004 | 08:57 PM
nocturnaldragon's Avatar
Default Re: (Andres-eh2)
There is a master cylinder for the clutch system. Altho its allways reffered to as the Clutch master cylinder
Edit:
You could allways put a little patch of Jb-Weld depending on where it is, but id recomend going up to the local salvage yard and picking one up that way.
Old Aug 11, 2004 | 09:56 PM
IVI's Avatar
IVI
look into how much a rebuilt/new one will cost you.
Old Aug 11, 2004 | 10:30 PM
DelSolSi93's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syner-G-Racing &raquo;</TD></TR><TR><TD CLASS="quote">I would suggest you bleed the lines, it sounds like air in the lines. if that doesent fix it then you may want to check for leaks related to the master cylinder, maybe a rebuild is in question. </TD></TR></TABLE>
Thats the most likely thing, good advice
Old Aug 11, 2004 | 10:44 PM
=GAME='s Avatar
go get one at autozone for about 40-50 bucks.
Old Aug 12, 2004 | 01:29 AM
Default Re: Clutch Pedal ? (=GAMEOVER=)
If you like to learn about your car get a helms manual (or haynes) and go buy a overhaul kit for the clutch master cylinder. Its not very hard...especialy if you can read and your not allergic to dot 3 or 4 brake fluid
Im sorry I just read your first post...obviously if you rebuilt your engine this is no major task for you. good luck
Old Aug 12, 2004 | 03:10 AM
civiceg500's Avatar
Where could i get a rebuild kit, my uncle says they don't sell those.
Old Aug 13, 2004 | 11:16 AM
get one through the dealership...it will be more expensive than a local parts supplier but its a direct replacement. If you want to save a little money try auto zone, advanced auto, pep boys, checkers, car quest, napa will be your best bet for imports...but you can definately get it through the dealer. Remember...a rebuild kit usualy contains seals, gaskets, orings, etc....an overhaul kit normal contains seals, gaskets, orings, hardware, and components in your case boots and so forth. you get the idea. they may only offer an overhaul kit so go to the parts department at honda and get some info and a base price before you shop around. thats what I always do. good luck.
or you could do the more expensive less painful way and just replace it.
Old Aug 14, 2004 | 01:36 PM
civiceg500's Avatar
I think I just figured something out, when i was looking at the master cylinder at the fire wall. I saw that the threaded line that goes from the cylinder to the resevior is soaked in clutch fluid. I personally think the master cylinder is good, just the line got weak and is letting fluid out and air into my system. What do u think?
Old Aug 14, 2004 | 01:40 PM
SiYouLater's Avatar
try replacing it and bleeding it.
Old Aug 14, 2004 | 01:42 PM
civiceg500's Avatar
Default Re: Clutch Pedal ? (99FBPSi)
92-95 civic clutch lines, are there any special type of lines that go to the master cylinder and the resivior or where can i find a braided hose for the clutch?
Old Aug 14, 2004 | 01:55 PM
blaster834's Avatar
Definatly need to bleed the lines
Old Aug 16, 2004 | 05:09 PM
Default Re: (blaster834)
sounds like you found the problem.
Old Aug 16, 2004 | 06:11 PM
lilCivic's Avatar
try bleeding it and c if there air in the system .......how it go
dgerej2
Oct 1, 2009 07:16 AM
RDAYA0
Dec 14, 2006 05:31 PM
92eg6lsvtec
May 20, 2006 05:56 AM
714JDMBB4
Aug 29, 2005 05:34 PM
