has anyone put piston oil squirters in ls block for ls/vtec
Old Nov 30, 2001 | 06:02 AM
internet ay's Avatar
Default has anyone put piston oil squirters in ls block for ls/vtec
i have oil squirters in my b16 block that i want to transfer over to to the ls for the ls/vtec. has anyone done it if so was it hard and how did you do it
Old Nov 30, 2001 | 06:13 AM
WAFFLES's Avatar
Default Re: has anyone put piston oil squirters in ls block for ls/vtec (internet ay)
I am building an ls/vtec...and it is very hard to do from what I've researched.
There is a lot of risk of damaging your block. I believe you need spacers for the squirters. Although it's a very nice upgrade, I might consider forged pistons over the squirters.
Old Nov 30, 2001 | 06:17 AM
Default Re: has anyone put piston oil squirters in ls block for ls/vtec (WAFFLES)
id like to have both
Old Nov 30, 2001 | 06:34 AM
RyanR's Avatar
From what I've been told, the oil lines are in the block so all you have to do is drill and tap for the squirters. You'd have to have a good machine shop do this but it sounds possible. I believe you would also have to change out the pistons for VTEC pistons or notch the LS pistons to clear the squirters.
Old Dec 1, 2001 | 06:55 AM
jgale's Avatar
Payn Technologies put them in my b20vtec. 248 362 0283 ask for Tom or Kevin. Use me as ref.
Old Dec 1, 2001 | 11:13 AM
One8Hatch's Avatar
New User
Default Re: has anyone put piston oil squirters in ls block for ls/vtec (jgale)
is this a very expensive mod to do? im taking my block into the machine shop to get some stuff done, about how much does oil squirters cost to install, i already have a set from my old b16, thanks
Old Jul 17, 2003 | 09:16 AM
6SPD_EK's Avatar
Default Re: has anyone put piston oil squirters in ls block for ls/vtec (One8Hatch)
back from the dead? I would like some more info, anyone else put squirters in a LS or B20 block? any problems related to this??? any info would be greatly appreciated
Old Sep 12, 2003 | 09:10 PM
Reza.dc's Avatar
Default Re: has anyone put piston oil squirters in ls block for ls/vtec (adirondackR)
i write rhymes in pitch blackness
libral00
Mar 30, 2008 09:57 AM
JDM_Frijoles
Sep 18, 2006 06:48 PM
JUN-DA6
Jul 27, 2005 09:30 PM
CrazyCiv
Feb 19, 2004 12:31 PM
ls_vtec_b18a1
Oct 23, 2002 09:22 PM
