compression
Old Nov 30, 2001 | 12:51 AM
mex's Avatar
mex
Default compression
my boy wants to know about his compression....lets say he wants to run about 9-12 psi from his turbo...will his b18b be able to handle it without any work to the bottom end?
Old Nov 30, 2001 | 03:40 AM
E-lude78's Avatar
Default Re: compression (nyctuner)
It would hold up but not for long. Anybody that has turbo loves to bag on their motors. If your gonna maintain a stock bottom end, it'll eventually go. Your buddy should invest in some good aftermarket pistons, blockguard and ARP studs.
Old Nov 30, 2001 | 07:11 AM
Spade's Avatar
Default Re: compression (Mista B-one-seven)
And don't forget the RODS!
Old Nov 30, 2001 | 08:28 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: compression (Spade)
kaboom is less than a month.
Old Nov 30, 2001 | 08:37 AM
spyder's Avatar
New User
All depends on how it is tuned. If it is tuned very well and driven smartly (not to say lightly, just don't go smashing into the rev limiter), then it should hold up fairly well. But just to be on the safe side, I would build the bottom-end at least a little. If nothing else, get stronger rods.
Old Nov 30, 2001 | 09:13 AM
vtecvoodoo's Avatar
Future Texas Boy
Community Builder
Default Re: compression (spyder)
it depends on his compression test and leakdown numbers, but it will blow.
Old Nov 30, 2001 | 05:15 PM
fsarfino's Avatar
Default Re: compression (vtecvoodoo)
Say away from the Blockguard the reason it makes the top of the cylinder not get properly cooled and can cause detation but the other advice is good. Besides on 9-12 psi a properly tuned B18 should have no problems
[Modified by dohcvtec16, 8:16 PM 11/30/2001]
Old Nov 30, 2001 | 05:39 PM
spyder's Avatar
New User
Default Re: compression (DragonCTR69)
The guys from Jackson Racing use the stock rods and claims that they are just fine for their Supercharged SOHC VTEC engine....
Yeah, and the JRSC is considdered a BOLT-ON kit, meaning it was made to be used with no serious modification to the rest of the engine, so they darn well better be using the stock rods! Also, the boost is much less than the 9-12 from the turbo (and no, I'm not comparing 9psi supercharged, vs. 9psi turbo, 9psi from a turbo gives greater gains).
o0o_tylor_o0o
Dec 7, 2010 07:03 PM
baynedo
Oct 11, 2006 05:35 PM
GSRerrr
Apr 4, 2005 07:11 PM
turbo_racer
Aug 21, 2004 12:51 AM
wrXtian
Oct 17, 2002 10:16 AM
