Turbo XS MBC....leakage normal???
Old Aug 9, 2004 | 01:53 PM
HXMan's Avatar
Default Turbo XS MBC....leakage normal???
My turbo xs mbc makes an air leaking noise at idle. If I pinch the hose feeding the boost controller from the intake manifold I can hear the hissing stop, and the WG makes a noise like it is closing....
Is this normal?
Old Aug 9, 2004 | 04:17 PM
HXMan's Avatar
Default Re: Turbo XS MBC....leakage normal??? (HXMan)
Bump, I know alot of people have turbo XS MBCs....
Old Aug 9, 2004 | 05:06 PM
sneakypete's Avatar
Yes this is normal. My friends does the samething and his holds boost fine.
Old Aug 9, 2004 | 05:33 PM
BoostedGSRBubble's Avatar
Default Re: Turbo XS MBC....leakage normal??? (sneakypete)
thats how it works, it bleeds off pressure so your wg will see less boost.
Old Aug 9, 2004 | 05:35 PM
HXMan's Avatar
Default Re: Turbo XS MBC....leakage normal??? (BoostedGSRBubble)
Mine holds boost fine. I just don't see why the boost controller should leak until boost hits the set level.
Old Aug 9, 2004 | 06:18 PM
toolowsol's Avatar
it bleeds air off so the wastegate doesn't see boost presure, when it hit the set pressure, it stops leaking and forces the air to the wastegate to open it.... That is how they work..
PM-Performance
May 12, 2006 07:15 AM
86si
Jul 31, 2004 10:21 AM
Nextelbuddy
Jun 15, 2004 07:57 AM
r1lorenzini
Feb 19, 2004 11:54 AM
B18badboy
Jan 13, 2004 08:06 PM
