How do boost controllers really work?
Old Jan 13, 2004 | 07:35 PM
B18badboy's Avatar
Default How do boost controllers really work?
I've searched, and I still can't find anything on how boost controllers physically work. I know they are used to prevent boost spike and boost creep, but if I knew the actual mechanics involved in this process it would be very helpful. And if it's already been covered, please point me to the right thread.
Thanks
Old Jan 13, 2004 | 07:45 PM
redboost10's Avatar
Default Re: How do boost controllers really work? (B18badboy)
good question, if anyone knows specifically the blitz sbc-id. i know the blitz uses a little black air box that directs air to the wastegate to keep it closed? am i right?
Old Jan 13, 2004 | 08:01 PM
*Boostwerks*'s Avatar
They use a combination of solenoids, and electronic switches to hold the actual boost pressure from the wastegate.
The most effective ones will hold the boost pressure completely from the wastegate (the gate see's 0 PSI) until the turbo spools up to the preset boost level of the controller. This allows the turbo to spool up faster compared to just using the wastegate.
The high end boost controllers also factor in settings for what gear your in, or RPM to adjust the amount of boost the gate sees.
Old Jan 13, 2004 | 08:06 PM
B18badboy's Avatar
Default Re: (Bryson)
I understand what you're saying but how do boost controllers work in a sense to prevent boost creep or boost spike; limit boost instead of prolonging it? I'm trying to set my internal wastegate at 7psi and make it stay there.
builtboostedteg
Apr 5, 2006 05:19 PM
stockgreencivic
Apr 10, 2003 07:32 PM
Tru Dynamix
Sep 14, 2002 03:58 PM
Cyrio
Dec 4, 2001 07:00 PM
