Just put on Grond Controls
I just put on a set of Ground Controls and took my car to get an alignment. Turns out I am at -1 degree of camber all around. How long do you think the inside of my tires will take to wear?
-1 degree all around isn't bad at all. Hell, I think that's within the factory range for the rears - or maybe it's the fronts, I forget.
But anyway, yeah - as long as your toe is zeroed out, I doubt you'll notice any uneven wear.
Thanks thats the answer I was looking for. Looking at the the factory spec is -1.0 - +1.0 for the fronts and -1.8 to .3 in the rear. I am at -1.0 in the front and -1.2 in the rear, with about .02 degrees of toe all around.
4-wheel computerized alignment from a typical place is $40-60. If you've installed camber kits that you want them to set up they sometimes charge more.
A Type-SH super-whammy job w/ the whole ATTS alignment procedure from a dealer will be at least $100 - but it's not necessary unless you're having problems with it.
shattergsr
Jul 16, 2002 08:46 AM
