Does the Drag 3 Kit required block cutting?
Depends on the manifold and some other things, if it is a premade kit chances are they've already done the majority of the things to make sure it would work. Be sure to ask any of the dealers though before actually buying it, I think the drags you may have to cut though, don't know about the others.
who did the cutting for you??
is there alot of cutting?
yes, had to cut the block to clear the compressor housing......thats drag III on a gsr...
you have to grind about 1" square out of the webbing around the block. not too major, just get a good grinder wheel, doesnt take long.
Since I'm new to turbo, does the size of the compressor make a power difference? Which is a better choice for more power?
the T04e is really big, and will make really big power.....most likely more than you will ever be able to use. im sure ill never even come close to maxing out this turbo.
That is correct becaue the Drag 3 for the Civic Si and Ls come with a TO4B compressor housing. Now, since you have a ITR and you do not want to shave the block webbing, then you can order a to4b with the kit.
art
art
get a 3/8" drill bit and a electrical drill, I cut about 1" off the block and still have about 1/3" clearance between the compressor housing and the block...
then use a smaller bit to cut the sharp edges left by the bigger bit
it only took me about 15-20 minutes to get it done, afterwards use a grind to smooth the edges out...
no biggie...
no biggie...
i just helped my friend install a custom kit on his b16a. We had to modify the block a little. We did all the work ourselfs..took about an hour or so.
...here are some pictures...
liam
liam
I've heard some people say they didn't need to do it. It's not that big of a deal, not like you're messing w/ the internal or anything.
Like Ben said, it all depends on how you position the housings. When I first installed the kit, I didn't need to modify the block. When I built the motor 2 years later, I decided to turn the compressor a tad CCW. After I finished the install and cranked it, I noticed the shaft in the turbo was stuck! So I cut the block with a small hand saw with the turbo still in tact.
-JP
-JP
