Black smoke when WOT?
Old Aug 7, 2004 | 12:26 PM
SlowGreenEJ's Avatar
Default Black smoke when WOT?
As title states. I did a compression test recently and had 160 across the board. The only thing I could think of is the valve seals. Again the only time the exhaust blows the smoke is when I am WOT. I NEVER rev my engine in neutral so I don't know if it does it then. Any ideas? If it the seals, where can I find them?
Thanks
JON
Old Aug 7, 2004 | 01:06 PM
Boltz's Avatar
Default Re: Black smoke when WOT? (redrex02)
Black smoke = running rich
Old Aug 7, 2004 | 01:08 PM
GZERO's Avatar
if you see black smoke is because the car is overly rich, not because of oil, so check your tunning and check injectors, spark plugs and air filters.
Old Aug 8, 2004 | 08:24 PM
It isn't black, its somewhat a white maybe, cant really see it unless its at night and you got headlights on the exhaust.
Old Aug 8, 2004 | 08:57 PM
-faded-'s Avatar
Default Re: (redrex02)
is it whitish, blue?
Old Aug 8, 2004 | 09:25 PM
GZERO's Avatar
ok, white means water burning, now, i bet it's blueish and i guess it means valve guide seals.
Do this.
Let the car idle for a while, and then stump on the throtle and see if you get a cloud of smoke, if you do, valve guide seals.
Old Aug 9, 2004 | 08:50 AM
Cool, thanks!
Old Aug 9, 2004 | 04:40 PM
Bump
joehonda1129
Nov 29, 2007 02:35 PM
GSR_hatch936
21
Apr 28, 2007 11:10 PM
ek2k
May 25, 2005 01:17 PM
suckanut
10
May 14, 2005 04:10 PM
egracer44
23
Oct 3, 2003 06:25 AM
