14.7 psi on stock b16 block?
Old Aug 5, 2004 | 02:32 PM
crazyimport's Avatar
Default 14.7 psi on stock b16 block?
Hi
im just wondering if i would be able to run a 1 bar on my stock b16 motor....
i have rc440cc injectors, walbro fuel pump and itr valvetrain....
would she be able to handle this amount of boost? im running 7 right now
and im getting tuned and dyno'd on tuesday... wondering if it would be safe to run it or not.
Old Aug 5, 2004 | 02:37 PM
braintree's Avatar
Default Re: 14.7 psi on stock b16 block? (crazyimport)
Depends on the turbo. The stock block can hold roughly 300 hp depending on tuning.
Old Aug 5, 2004 | 02:45 PM
Default Re: 14.7 psi on stock b16 block? (braintree)
its a drag garret t3 turbo
Old Aug 5, 2004 | 02:50 PM
Gesundheit's Avatar
detonation kills motors, not pressure
Old Aug 5, 2004 | 02:55 PM
Default Re: 14.7 psi on stock b16 block? (Crankdriven)
what hp should i be able to get at the wheels with my current setup ?
garret t3 turbo/ rc 440cc injectors / 7psi / itr valvetrain
Old Aug 5, 2004 | 02:58 PM
Gesundheit's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">what hp should i be able to get at the wheels with my current setup ?
412.57WHP @7589.9 RPM's
Old Aug 5, 2004 | 02:59 PM
lol **** off
im serious
i got a dyno appointment next week.... wondering what i should b pushing
Old Aug 5, 2004 | 03:39 PM
anyone ?
Old Aug 5, 2004 | 04:39 PM
red cx's Avatar
I run 15 psi on my stock b16 with a 60-1 daily
Old Aug 5, 2004 | 06:12 PM
TurboJesse
Guest
Posts: n/a
Default Re: 14.7 psi on stock b16 block? (red cx)
i ran 14-15 daily with a t3/to4e 60 trim...
Old Aug 5, 2004 | 08:07 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red cx &raquo;</TD></TR><TR><TD CLASS="quote">I run 15 psi on my stock b16 with a 60-1 daily </TD></TR></TABLE>
serious??? ok damn i should do this then
ever had any problems with it ??
track times? hp ?
Old Aug 5, 2004 | 08:15 PM
TurboJesse
Guest
Posts: n/a
track times? hp ?</TD></TR></TABLE>
no problems...i do have a thick headgasket to lower compression....
no track times as i have a built C1 now but the b16a had no problems hanging with my friends supra's from a roll that trap 120-122 ish
Old Aug 5, 2004 | 08:18 PM
Default Re: 14.7 psi on stock b16 block? (Mpir3)
damn ok.. i should do this then...
i also have the itr valvetrain in there so it should b able to help out a bit
what size injectors did you have thou ?
im only running 440's
Old Aug 5, 2004 | 08:24 PM
TurboJesse
Guest
Posts: n/a
i had dsm 450's...they were maxed out though
Old Aug 5, 2004 | 08:26 PM
so i should b able to push them then.. hmmmm
Old Aug 5, 2004 | 09:12 PM
auto moto's Avatar
if your running 440's what fuel managment do you have to control them?
Old Aug 5, 2004 | 09:46 PM
Default Re: 14.7 psi on stock b16 block? (suki sauce)
running CROME ... kicks ***
Old Aug 19, 2004 | 03:44 PM
89efhatchy's Avatar
what is crome?
Old Aug 19, 2004 | 04:14 PM
USDM 4G VTEC's Avatar
if u going for dyno tunning
the tuner should know what kind of power he can push out of ur car as long as he tunes it right.....
he should know and have an idea of where are the limits.....
Old Aug 24, 2004 | 04:13 PM
Boosted Chemist's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crazyimport &raquo;</TD></TR><TR><TD CLASS="quote">running CROME ... kicks ***</TD></TR></TABLE>
thank god i though you were going to say vfac hack lol,
im running 10 psi on a Turboedit homemade base map with a b16a t3t4 57trim .63 a/r no problem, i would like ot turn it up but i dont want risk too much until i get a wideband
Old Aug 24, 2004 | 04:26 PM
leed's Avatar
Default Re: 14.7 psi on stock b16 block? (Mad Chemist)
If your on stock compression Id deff. keep an ear out for detonation. When I had my t3 on my 10.2 CR B16 @14psi, is was on the very edge of pinging. Id go very soft on the timing. Like around 15-16* IHMO.
12psi would be what Id recommend to ensure a long happy engine life. Just my .02
PS, I ended up making 238 at 8-10psi and 277 @ 14-15psi w/ a 60/63 T3. Goodluck
88 EF Hatch
Aug 2, 2011 06:50 AM
ser13
Nov 3, 2007 05:03 AM
Doostur
Jul 3, 2007 04:05 AM
mugenDA9 lover
Nov 9, 2006 07:36 PM
meanB6teen
May 10, 2005 07:56 PM
