Teflon caoting on JRSC.
Old May 3, 2004 | 01:06 PM
HYREV2NR's Avatar
Default Teflon caoting on JRSC.
I've heard several different things on this subject. One is if you run high boost (I'm guessing 9lbs. or more) the inake temps will get high enough to cook the coating off of the rotors. Is this true? I called J.R. & they said it's safe to 900 dgrees F. I could understand this if some foreign object such as a small debri, sand etc. entered the intake. But, I know several people that have installed used chargers with the caoting chipped off but they seem to have no other problems no matter what boost level they are running. So whats the big hype about this teflon? N E 1?
Modified by HYREV2NR at 12:27 AM 5/4/2004
Old May 3, 2004 | 01:36 PM
HT Chaplain's Avatar
Loved
Default Re: Teflon caoting on JRSC. (HYREV2NR)
The teflon once chipped off keeps chiping off and goes into your motor
Old Aug 22, 2004 | 08:18 AM
icivicracer's Avatar
Default Re: Teflon caoting on JRSC. (HT Chaplin)
what if the teflon is all the way off ????? thats how mine is due 2 water....ttt
Old Aug 23, 2004 | 06:23 PM
NVMYSi's Avatar
Default Re: Teflon caoting on JRSC. (icivicracer)
I had all the teflon removed when my jrsc was rebuilt. I ain't cooking eggs on it so why have it. How may other engine parts have teflon coating....zero. So, that leads me to believe it is a gimmick.
Old Aug 23, 2004 | 08:18 PM
diulay_pkjai's Avatar
wouldn't the teflon make the sc more efficient since it reduces friction.
Old Aug 23, 2004 | 08:27 PM
ion_four's Avatar
icivicracer, that is the best avatar, evar.
...900º seems scarey hot for intake temps...like there's no way you wouldn't be detonating hundreds of degrees before that.
Old Aug 24, 2004 | 04:46 PM
Default Re: Teflon caoting on JRSC. (ion_four)
so if all the teflon is off and the sc spins fine....it should be o.k wit teflon off??.
Old Aug 24, 2004 | 04:50 PM
<------ dont stare 2 long u will go blind
protopro88
Apr 7, 2011 09:14 PM
fat_cat
May 2, 2007 10:04 PM
siis2fast
Jun 25, 2003 09:22 AM
redteg
Mar 26, 2003 09:57 AM
