Over Heating Problem
I have a wierd problem ....
When I am in traffic or on the open road my temp is fine ... but then I go over 80 the engine temp goes up up up .... I slow down under 80 and temp goes back to normal .....
I have replaces the thermostat because I thought it may be going bad but it didnt fix the problem
any ideas?
thanks
any ideas?
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdaggett »</TD></TR><TR><TD CLASS="quote">I have a wierd problem ....
any ideas?
thanks</TD></TR></TABLE> THAT IS WEIRD,IT SHOULD B THE OTHER WAY AROUND
any ideas?
Bump to get yours and mine problem solved..
Also if you turn the heat on it will fix the problem?
Just did:
- act clutch kit
- rear main seal
- thermostat
- fidanza flywheel
- complete head set
- flushed coolant
I'm thinking radiator because my fan comes on..
TTT for two people with the same problem
Am
Just did:
- act clutch kit
- rear main seal
- thermostat
- fidanza flywheel
- complete head set
- flushed coolant
Am
cbr_ryder
Classic Hondas
16
Jul 28, 2023 07:13 AM
cbr_ryder
Classic Hondas
Jan 6, 2022 05:47 PM
