Over Heating Problem
I have a wierd problem ....
When I am in traffic or on the open road my temp is fine ... but then I go over 80 the engine temp goes up up up .... I slow down under 80 and temp goes back to normal ..... I have replaces the thermostat because I thought it may be going bad but it didnt fix the problem any ideas? thanks |
Re: Over Heating Problem (rdaggett)
is your radiator fan clicking on
Re: Over Heating Problem (IH82LOSE)
i will have to check that .... any other ideas anyone?
maybe ur coolant is running out?...
Check for any leaks in ur coolant hoses? are u leaking any coolant? |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdaggett »</TD></TR><TR><TD CLASS="quote">I have a wierd problem ....
When I am in traffic or on the open road my temp is fine ... but then I go over 80 the engine temp goes up up up .... I slow down under 80 and temp goes back to normal ..... I have replaces the thermostat because I thought it may be going bad but it didnt fix the problem any ideas? thanks</TD></TR></TABLE> THAT IS WEIRD,IT SHOULD B THE OTHER WAY AROUND |
coolant always full no leaks
anyone else?
Bump to get yours and mine problem solved..
Also if you turn the heat on it will fix the problem? Just did: - act clutch kit - rear main seal - thermostat - fidanza flywheel - complete head set - flushed coolant I'm thinking radiator because my fan comes on.. TTT for two people with the same problem https://honda-tech.com/forums/images...s/emsmilep.gif Am |
Re: (Jimmy)
when was the last time you put in a water pump?
