Over Heating Problem
Old 07-31-2004, 01:29 PM
rdaggett's Avatar
Default Over Heating Problem
I have a wierd problem ....
When I am in traffic or on the open road my temp is fine ... but then I go over 80 the engine temp goes up up up .... I slow down under 80 and temp goes back to normal .....
I have replaces the thermostat because I thought it may be going bad but it didnt fix the problem
any ideas?
thanks
rdaggett is offline
Old 07-31-2004, 01:35 PM
IH82LOSE's Avatar
Default Re: Over Heating Problem (rdaggett)
is your radiator fan clicking on
IH82LOSE is offline
Old 07-31-2004, 01:44 PM
rdaggett's Avatar
Default Re: Over Heating Problem (IH82LOSE)
i will have to check that .... any other ideas anyone?
rdaggett is offline
Old 07-31-2004, 01:51 PM
Jockdeeznutz's Avatar
maybe ur coolant is running out?...
Check for any leaks in ur coolant hoses?
are u leaking any coolant?
Jockdeeznutz is offline
Old 07-31-2004, 02:04 PM
honda9369's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdaggett &raquo;</TD></TR><TR><TD CLASS="quote">I have a wierd problem ....
any ideas?
thanks</TD></TR></TABLE> THAT IS WEIRD,IT SHOULD B THE OTHER WAY AROUND
honda9369 is offline
Old 07-31-2004, 02:34 PM
rdaggett's Avatar
coolant always full no leaks
rdaggett is offline
Old 07-31-2004, 08:33 PM
rdaggett's Avatar
anyone else?
rdaggett is offline
Old 07-31-2004, 08:52 PM
Global Moderator
Jimmy's Avatar
Bump to get yours and mine problem solved..
Also if you turn the heat on it will fix the problem?
Just did:
- act clutch kit
- rear main seal
- thermostat
- fidanza flywheel
- complete head set
- flushed coolant
I'm thinking radiator because my fan comes on..
TTT for two people with the same problem
Am
Jimmy is offline
Old 08-11-2004, 12:48 PM
shorty91's Avatar
Default Re: (Jimmy)
when was the last time you put in a water pump?
shorty91 is offline
ARMED
Honda CR-V & Element
05-03-2014 09:28 AM
iani_2006
12-14-2005 07:40 AM
crxtreme27
11
09-01-2002 05:37 AM
Quick Reply: Over Heating Problem
  • Ask a Question
Question Title:
Description:
