1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!!
Old Jul 26, 2004 | 07:12 PM
jmk2888's Avatar
Default 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!!
I have a 1996 ITR Motor and now I need to change my DISTRIBUTOR.
By the way, I have MSD SCI w/ Blaster Coil, anf MSD Cap.
Is the GSR and ITR distributor the same ?
Is the USDM and the JDM distributor the same?
OEM from Acura is like $500.00, I was considering to buy one from the "DISTRIBUTOR KING" doe anyone have experience with their products????
When I drive, around 4000-5000 RPM my tach jump up and down quickly.
I check all grounding and it's fine. I went to a performance shop and they told same thing it's the distr. going bad. Any suggestions?
Any help is greatly appreciated.....
Many Thanks...................
Modified by jmk2888 at 4:48 AM 7/27/2004
Modified by jmk2888 at 6:14 AM 7/27/2004
Modified by jmk2888 at 4:02 AM 7/28/2004
Old Jul 27, 2004 | 12:35 AM
96dc2's Avatar
Default Re: 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!! (jmk2888)
JDM and USDM should be the same. Any OBD2 b-series VTEC distributor will work with your motor. The caps may be different, though. I have a '00 Si distro in my '96 GS-R, and was going to put the GS-R cap on but it didn't fit.
Old Jul 27, 2004 | 07:53 AM
jmk2888's Avatar
Default Re: 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!! (96dc2)
I have MSD Cap and SS Blaster.
Should just go to Acura and buy the Distributor Housing for like $250.00 instead buying the whole distributor?
Cause I do not need the Coil and Ignitor, right?
Old Jul 27, 2004 | 03:06 PM
jmk2888's Avatar
Bump:
Old Jul 27, 2004 | 04:41 PM
emotionisdead's Avatar
Very Emergency!!
my friend got an obd0 dizzy from dist. king and it was amazing in quility and price. go for that one, don't waste anymore money than you have to by buying from acura.
Old Jul 27, 2004 | 05:10 PM
Maximus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96dc2 &raquo;</TD></TR><TR><TD CLASS="quote">JDM and USDM should be the same. Any OBD2 b-series VTEC distributor will work with your motor. The caps may be different, though. I have a '00 Si distro in my '96 GS-R, and was going to put the GS-R cap on but it didn't fit.</TD></TR></TABLE>
He has a 92-95 civic coupe, you need to change your cap to work with OBDI. Ask in the hybrid forum, you will get a faster response there.
Old Jul 29, 2004 | 05:39 PM
jmk2888's Avatar
Default Re: 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!! (Maximus)
Actually, now I'm experiencing some hestitating and it's not going into VTEC.
Only when the car is hot during drive.
It's actually getting worse, any more advice?
Old Jul 29, 2004 | 05:52 PM
mugenracer's Avatar
does it have one or two plugs (the grey ones at the back of it)?
Old Jul 29, 2004 | 06:02 PM
jmk2888's Avatar
Default Re: 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!! (mugenracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugenracer &raquo;</TD></TR><TR><TD CLASS="quote">does it have one or two plugs (the grey ones at the back of it)?</TD></TR></TABLE>
It has 1 plug
Old Jul 29, 2004 | 07:37 PM
BudMan's Avatar
Call Pat at Distributor King & tell him I sent you (plus you'll get a 10% discount for mentioning ITRCA.com). He'll hook you up with whatever you need at a good price - MUCH less expensive then OEM.
FWIW - I've been running his full distributor on my R for ~ 15,000 miles & no problems. I run in all of the advanced groups for road events like the Expo, Porsche club, Audi club, Corvette club, etc...
Pat is "double thumbs-up".
Jeff Goodnow
Design Coordinator http://www.itrca.com
BudMan
913-522-3002
jeff@itrca.com
Old Jul 31, 2004 | 12:33 PM
jmk2888's Avatar
Default Re: 1996 ITR DISTRIBUTOR, help!!!!!!!!!!!!!!!! (BudMan)
Thanks fo rthe all the advice.
I finally got a new distr. housing from Acura Carland for like $260.00 and everything is fine now.
Damn HONDA Distr.....
skata89
Mar 9, 2008 12:50 PM
angela_itr
Apr 12, 2005 02:42 PM
jmk2888
Jul 31, 2004 12:34 PM
Mike95lude
Oct 27, 2003 01:02 PM
boosted1993fd
Jun 3, 2002 11:39 PM
