Low Fuel Light....
Old Jul 25, 2004 | 10:42 AM
civic_speed99's Avatar
Default Low Fuel Light....
I noticed that my low fuel light wasn't working when i ran outta gas downtown the other night... luckily i was right by the gas station and i got it started again.....
what could be the problem since it won't light up??
Old Jul 25, 2004 | 10:45 PM
ek9800's Avatar
Default Re: Low Fuel Light.... (civic_speed99)
either ur light bulb popped out or there was not one in there or its deffected
Old Jul 25, 2004 | 10:59 PM
skrewdriver88's Avatar
Default Re: Low Fuel Light.... (jdm98hb)
I have the same problem too man. It sucks ***
Old Jul 25, 2004 | 11:46 PM
vtecpower1062's Avatar
I had the same problem too recently, only I got stuck on I-95 and had to get towed . I am going to troubleshoot this with Honda service manual and ETM. Hopefully its something simple like a fuse.
Old Jul 26, 2004 | 03:39 AM
JimmyAtlantis's Avatar
Default Re: Low Fuel Light.... (vtecpower1062)
Are you guys sure you even have a low fuel light? I know I don't - as in the car was built without one.
Old Jul 26, 2004 | 05:01 AM
photec2's Avatar
Default Re: Low Fuel Light.... (JRI94)
^ i was gonna say that also but according to your sig's 00 si and 99 EX im sure you have a low fuel light. In my case my 93 si doesn't even have one.
Old Jul 26, 2004 | 05:07 AM
Sijray21's Avatar
Your guage works right?
Fill up before it gets to that point
Old Jul 26, 2004 | 05:22 AM
CRITTERMATT's Avatar
most likely your sending unit needs replaced. The same thing happened to mine. The sending unit is located in the tank behind the fuel pump.
Old Jul 26, 2004 | 08:05 AM
SlepT ej6's Avatar
Default Re: Low Fuel Light.... (Sijray21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sijray21 &raquo;</TD></TR><TR><TD CLASS="quote">
Fill up before it gets to that point </TD></TR></TABLE>
definately
Old Jul 26, 2004 | 01:03 PM
undertheradar's Avatar
Default Re: Low Fuel Light.... (SlepT ej6)
If my 97 Dx has one...yours does. I'd say it's the sending unit and or the bulb in the cluster. I'd check the bulb first though...it's easiest to get to and the cheapest to buy.
Old Jul 26, 2004 | 01:12 PM
doublejz's Avatar
Default Re: Low Fuel Light.... (CRITTERMATT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRITTERMATT &raquo;</TD></TR><TR><TD CLASS="quote">most likely your sending unit needs replaced. The same thing happened to mine. The sending unit is located in the tank behind the fuel pump.</TD></TR></TABLE>
No, as long as your gauge is reading correctly your sending unit works fine. The low gas light goes by the position (voltage) of where the needle is. If you have a light and its not working, its most likely your bulb
Old Jul 26, 2004 | 02:49 PM
Default Re: Low Fuel Light.... (doublejz)
I have to disagree. Because mine quit working and once I replaced the sending unit it began to work. The low fuel light sensor is made into the sending unit.
Old Jul 26, 2004 | 03:09 PM
soundbomber's Avatar
mine has never worked and i have a 98 dx
Old Jul 26, 2004 | 03:12 PM
Dyzee's Avatar
I've never had mine on. Heck I dont even know if I have one.
I drove my car almost 600kms on 35L of fuel and it still didnt come on. I got scared so I filled her up
Atauto
Honda CR-V & Element
Aug 2, 2015 02:25 PM
rdone
Jan 5, 2015 04:01 PM
dlbazini
Apr 4, 2009 03:21 PM
wernhersey
Mar 2, 2007 06:27 AM
tkevin07
Apr 5, 2006 05:24 PM
