boost leak question, this time I cant find it.
I'm working on finding a boost leak. I hooked up electric air pump to my charge pipes and it sits at 7psi. 7psi is where my boost controller is set to. When I drive, I will hit 7psi quickly then drop to 5psi. I assume this is a major boost leak since it used to not do this. I have had plenty boost leaks in the past but soapy water + the air pump would always find them. Anyone have any ideas?
Nick
Nick
Well Its most likely a leak not any parts malfunctioning. As you said before it gets boost but it drops, so check all connections and make sure that none of the charge piping is not leaking or cracked. Let us know what happened and how you fixed it.
