Does my Wastegate Valve look normal???
Old Jul 22, 2004 | 06:40 AM
busakiller's Avatar
Default Does my Wastegate Valve look normal???
When looking through the dump side you can see a gap.. Is this normal when you have the wastegate off without having the vacuum hooked up to it... Here's some pics to describe what i'm talking about...
Old Jul 22, 2004 | 11:50 AM
busakiller's Avatar
Default Re: Does my Wastegate Valve look normal??? (busakiller)
anyone???
Old Jul 22, 2004 | 11:56 AM
Jeffescortlx's Avatar
Well, I know with internal there spring loaded shut, untill the boost pressure pushes it open. So I'm gonna say there's somthing not right.
Old Jul 22, 2004 | 12:07 PM
busakiller's Avatar
Default Re: Does my Wastegate Valve look normal??? (Jeffescortlx)
Anyone else have a wastegate laying around to look at and see if it's open a little???
Old Jul 22, 2004 | 12:13 PM
gritsak's Avatar
the metal ring should compress down when you tighten the wastegate to the manifold to seal off the valve.
put something flat over the ring and tap it down and see if it will go down all the way and if there is still a gap or not
Old Jul 22, 2004 | 12:17 PM
busakiller's Avatar
Default Re: Does my Wastegate Valve look normal??? (gritsak)
I'm pretty sure the ring is all the way down on there but I'm not sure if it would seal when I bolt it down on the manifold...
Old Jul 22, 2004 | 12:23 PM
Johnyquest's Avatar
The ring is not all the way down. When you bolt it on it will seal, it's fine.
Old Jul 22, 2004 | 12:24 PM
PM-Performance's Avatar
from what i remember with my 35mm when i had it , it was just like that off the top og my head. it doesnt matter though, once you put the ring in and seat it on the manifold, its gonna push the plunger up more anyway. as long as it seals on the ring, youll be fine . and i can tell you from the look of the gap it will seal fine on the ring.
Old Jul 22, 2004 | 12:28 PM
busakiller's Avatar
Default Re: Does my Wastegate Valve look normal??? (itr206)
Cool.. Thanks guys.. Thats a relief... I thought I had a f#*ked up wastegate...
itr206: How can you tell mine wastegate is a 35mm???
Old Jul 22, 2004 | 12:30 PM
35/38, same **** to me . its got the 35mm flange on it.
but i was referring to when i had a 35mm and i took it off to inspect it the one time i saw mine was like that. i havent looked at my 40mm to see if its the same . i dunno , i was just adding detail to the story. lol
Old Jul 22, 2004 | 12:38 PM
busakiller's Avatar
cool.. thanx for the help everyone!!!!
Old Jul 22, 2004 | 02:11 PM
CRX T-Si's Avatar
I remember seeing a wastegate that does not shut when it's not hooked up.
I believe its this TurboSmart Brand.
Saw that thing in person at last year's Nopi Nationals, I questioned the guy at the booth and he said it works fine.
Old Jul 22, 2004 | 03:06 PM
{StatuS ChecK}'s Avatar
Default Re: Does my Wastegate Valve look normal??? (CRX T-Si)
I have that WaisteGate, I did't install it though, it is a very nice gate, sounds nice to, A boost controller is recommended with them, cause other wise you have to order a spring that i heard is a bitch to install!
Old Jul 22, 2004 | 04:59 PM
gritsak's Avatar
Default Re: Does my Wastegate Valve look normal??? ({StatuS ChecK})
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {StatuS ChecK} &raquo;</TD></TR><TR><TD CLASS="quote">I have that WaisteGate, I did't install it though, it is a very nice gate, sounds nice to, A boost controller is recommended with them, cause other wise you have to order a spring that i heard is a bitch to install!</TD></TR></TABLE>
sounds real nice i dont understand what purpose a wastegate has if it doesnt shut all the way..its just leaking off gas that would help spool the turbo
ill stick with my nice and simple tial
Old Jul 22, 2004 | 05:12 PM
CRX T-Si's Avatar
Hey gritsak you do see the first pic that the mounting flange is not flat right???
ludatic98
Dec 8, 2009 08:34 AM
ham
Sep 2, 2007 01:08 PM
Turbo_Mike
Jul 14, 2005 12:07 PM
Chuck Dean
Aug 9, 2003 04:20 PM
ezark
Oct 2, 2002 12:34 PM
