Double stacking head gaskets
doesn't Cometic make o.063" thick head gaskets
I would rather trust a head gasket designed to be that thick over two regular ead gaskets stacked.
not to mention that it would probably be cheaper to purchase the Cometic that it would be for two OEM headgaskets or aftermarket
Yep, I'm opposed to stacking 2... especially with boost.
Just asking before I try contacting cometic again this afternoon. It's always good to have all the area's covered in advance. Thanks daniel.
who's is it? Got someone else to cross over to the turbo world?
I was thinking of going turbo until I came across a JDM ITR swap for cheap....now I sell them, it is great
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude »</TD></TR><TR><TD CLASS="quote">yea i know that....i wasnt speaking literally</TD></TR></TABLE>don't worry about him Nick. He's an idiot
Toda also offers thicker-than-stock gaskets to lower compression, but if the build is extreme, you'd obviously be better off lowering the compression via pistons.
to make a long story short i hydro locked, warped the head which was already shaved and i allready have je 10:1's and my car has been down for almost 2 months so i just want to get it back on the road unless you know someone that wants to buy them
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dirtyd463 »</TD></TR><TR><TD CLASS="quote">doesn't Cometic make o.063" thick head gaskets
they make em even thicker than taht but get some came gears toget your timing back to normal.
Guest
Posts: n/a
It works, alot of cars up here do it sucessfully, i had it on an old setup. Just drill out the rivits and re rivit the 2 headgaskets together. Make sure to use copper spray and tq the headstuds an extra 5lbs.
Remember Precisionh23 is my Hero!!!
Well I remember the only difference in the H22 and H23 head gaskets was the fact that one of them had two open passages that the other one didn't have. It seems to me like it was the H22 that had the two closed passages...........
If you can get ahold of one of each, you'll see what I'm talking about. You may be able to just drill out the holes in an aftermarket headgasket to make it work.
Just a thought...
Just a thought...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a »</TD></TR><TR><TD CLASS="quote">Have any of you guys tried this and what were your results?</TD></TR></TABLE>
I'm using a mr.gasket stackable kit on my d-series. No problems at all.
