torque specs for exhaust manifold?
Old Jul 16, 2004 | 01:45 PM
donkiman's Avatar
Default torque specs for exhaust manifold?
i know i know i need a helms manual but could somebody tell me the torque specs for exhaust manifold on a 1998 usdm b18c1 motor. thanks
Old Jul 16, 2004 | 01:59 PM
smart monkey's Avatar
Default Re: torque specs for exhaust manifold? (donkiman)
I believe they are 19lbs for the studs on the head.
Old Jul 17, 2004 | 07:44 PM
sleepinbeauTEG's Avatar
Default Re: torque specs for exhaust manifold? (smart monkey)
double check cause snappin bolts is a B OTCHHH
Old Jul 17, 2004 | 09:46 PM
riceball777's Avatar
man you dont need to torque those bolts just tighten them untill they are tight. the stud will not brake
you really only need to torqur head bolts, cam caps, main bolts and stuff like that
you dont need to torque ex mainifold , im, bolts
Old Jul 18, 2004 | 02:21 AM
Sack Master's Avatar
Default Re: torque specs for exhaust manifold? (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">man you dont need to torque those bolts just tighten them untill they are tight. the stud will not brake
you dont need to torque ex mainifold , im, bolts </TD></TR></TABLE>
Agreed
Old Jul 19, 2004 | 11:11 AM
actually I have seen guys tighten those man studs and nuts to tight by hand and snap them and when they snap they are hard to get out. you can hand tighten yes but if you do just be careful.
Old Jul 27, 2004 | 07:34 AM
donkiman's Avatar
Default Re: torque specs for exhaust manifold? (Sack Master)
i must say that sack masters signature is awsome.
Old Jul 27, 2004 | 10:16 AM
Thank you sir
tpot90
Mar 13, 2009 07:35 PM
v930
Feb 16, 2005 08:22 PM
92-LS-Civic
Oct 7, 2004 07:47 AM
anothersickhatch
12
Jun 10, 2004 02:26 PM
