Engine Torque Specs
I was wondering if anyone knew a good website with torgue Specs for like the head bolts, crank, rod, cam, and all other major bolts. but mainly here is a list.
Head bolts
camshaft bolts
The cradle that hugs the crank in the middle
the rod bolts
intake manifold bolts / exuast manifold bolts
oil pan bolts
and anything else i should know when building the motor back together.
Thank you
Head bolts
camshaft bolts
the rod bolts
oil pan bolts
Thank you
The Helms manual shows all the torque specs you need. You could buy a paper copy, or if you have time, print out the necessary pages from a pdf version of the manual, as seen here:
http://www.redpepperracing.com...a-FSM
eortizr
Aug 23, 2005 10:08 PM
