IB spec I beam rods Can they take it?
Just wanted to know if anyone knows anything about IB spec rods and if they are good under boost. I have a set of the I beams and a set of JE 9:1 pistions and I'm planing on running 12#s daily and 20#'s at the track. The block is sleeved and I'll be running AEM EMS with a lot of tunning.
Thanks.
__________________
Thanks.
__________________
I think a better question to ask would be can they handle up to X amount of hp. Because people make different hp on the same boost. Does that make sense??? Call and ask would be your best bet...
hopefully they won't take 3 months to get like my sleeved block...
but .. the i beam rods are more for all motor type of applications and you should really consider the H beam rodsif you are going turbo.. the I beams are not meant to handle turbo pressure, they are made to be light..
