can timing change without adjusting it?
Old Jul 14, 2004 | 08:25 PM
igo4bmx's Avatar
Default can timing change without adjusting it?
I'm wonder if timing would change without any work done to it
Old Jul 14, 2004 | 08:38 PM
showtymers619's Avatar
* B A N N E D *
Default Re: can timing change without adjusting it? (igo4bmx)
ecu wise yes.. or if you get a knock
Old Jul 14, 2004 | 08:40 PM
BauleyCivic's Avatar
Risky Business
Default Re: can timing change without adjusting it? (ShowTymers619)
the ecu changes ignition timing based on inputs, but the distributor won't move itself
Old Jul 14, 2004 | 09:39 PM
4dohs4mohoes's Avatar
Default Re: can timing change without adjusting it? (BauleyCivic)
Im not sure if im right, but if the belt jumps a tooth or strecthes some how it will change your timing.
Old Jul 14, 2004 | 09:45 PM
nocturnaldragon's Avatar
Default Re: can timing change without adjusting it? (boo bees)
Timing belts to wear and losen up thats why theres a tensioner to help counteract that effect but once it gets worn to a point it just needs to be replaced, id say about every 90,000 miles or so?
Two400
33
Feb 10, 2017 07:07 AM
boomersz
Mar 4, 2007 07:55 AM
bart2546
Dec 31, 2006 06:30 AM
White86CRXSi
Aug 27, 2004 03:19 PM
Boostless97Lude
Jan 7, 2003 08:24 AM
