checking your timing.....
Old Jan 6, 2003 | 02:53 PM
Boostless97Lude
Guest
Posts: n/a
Default checking your timing.....
alrighty, i read the helms manual on how to check the timing, and it says you have to connect some kind of service connector... WTF is up with that, maybe i don't actually have to do that and i am just reading this damn book wrong, anyone got any thoughts?
Old Jan 6, 2003 | 03:06 PM
DR's Avatar
DR
Default Re: checking your timing..... (Boosted97Lude)
You can not adjust the timing on a H22A4 since it is controlled by the ECU. You can still check the timing with a timing light or through an OBDII scan tool but the only thing you can do if it is wrong is change the ECU.
Old Jan 6, 2003 | 03:08 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: checking your timing..... (DR)
um... then how come the distributer can rotate just like on my teg??
Old Jan 6, 2003 | 05:16 PM
Finest's Avatar
There's another connector down by the timing belt side...I believe it's some sort of crank angle sensor, which won't allow timing adjustments.
You need to convert to OBD-I distributor/ECU to be able to adjust the timing.
Old Jan 6, 2003 | 05:20 PM
Boostless97Lude
Guest
Posts: n/a
Default Re: checking your timing..... (98CTRCoupe)
i don't really ned to adjust it, i just wanted to make sure it was where it needed to be. not a good idea to start boosting the **** out of it with advanced timing ya know
Old Jan 6, 2003 | 07:51 PM
sslude's Avatar
yeah, i tried but it didnt work. it wouldnt move at all.
Old Jan 6, 2003 | 08:02 PM
sharkcohen's Avatar
If you want to datalog your ignition timing and do a whole lot more, check out http://www.pocketlogger.com I love mine, it has been invaluable.
Old Jan 7, 2003 | 02:52 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: checking your timing..... (sharkcohen)
the AEM EMS is one the way, so that would be pretty well pointles, but thanks for the idea anyways
Old Jan 7, 2003 | 05:05 AM
DirtyLude's Avatar
When you jump the service connector it locks the timing so you can check it against the indicator on the flywheel. Otherwise the timing is variable and you have no idea what you're checking against.
Old Jan 7, 2003 | 08:24 AM
Boostless97Lude
Guest
Posts: n/a
Default Re: checking your timing..... (DirtyLude)
ok then..... so there isn't a need to adjust the timing then... that was my only concern
NatedoggAZ
14
Apr 13, 2005 09:51 AM
integrx
May 12, 2004 02:48 PM
Nextelbuddy
Mar 30, 2004 10:09 AM
integranator
Oct 23, 2003 09:40 PM
H23 Power
Aug 27, 2001 08:03 PM
