im hitting just under .2bar.. somethings wrong, i have a few ideas
Old Nov 22, 2001 | 10:31 PM
DIRep972's Avatar
Smarter than you
Default im hitting just under .2bar.. somethings wrong, i have a few ideas
I finally got my boost gauge installed tonight so now I can trouble shoot my boost leak.. Im hitting just under .2bar or around 2.8psi or so.. My wastegate is not opening up and I have a .3bar spring.. ive narrowed it down to my BOV.. Im pretty sure its the problem but not 100% sure.. Last weekend we realized I had a boost leak through my BOV so we tightened it up a whole lot and were able to get my wastegate to open.. But the other day the wastegate stopped opening up again.. Now I have the BOV as tight as it goes and it still leaks boost.. Is there anything that could be causeing the BOV to open up prematurly or is it probably just a defective BOV?
[Modified by DIRep972, 7:33 AM 11/23/2001]
Old Nov 22, 2001 | 11:14 PM
LsTurbo91's Avatar
Default Re: im hitting just under .2bar.. somethings wrong, i have a few ideas (DIRep972)
If your wastegate wasn't opening you'd be boosting 20+ psi, That must be some major leak, you checked all your piping?
Old Nov 22, 2001 | 11:22 PM
dustin's Avatar
Default Re: im hitting just under .2bar.. somethings wrong, i have a few ideas (LsTurbo91)
So you have a .3 bar spring... but you are getting .2 bar.. where is the side port on the wastegate tapped? If it is the compressor then you are just getting loss across the intercooler.
Dustin
Old Nov 23, 2001 | 06:39 AM
BluLuder's Avatar
Default Re: im hitting just under .2bar.. somethings wrong, i have a few ideas (dustin)
I had a similiar problem.. I had a leak it was the exhaust manifold gasket... then we found the clamps on the IC piping
needed to be tightened.. still hitting low 2.8 psi. we changed wastegates.. still nothing changed, BUT the car runs stronger.
So I've boiled it down too the boost gauge is faulty. I've been stressn over it for weeks, I feel your pain!
I just dont see how its the BOV valve thats faulty, what wastegate are you running?
CHECK YOUR IC PIPING! make sure there is no leaks and did you change the exhaust manifold gasket when installing it?
Old Nov 23, 2001 | 09:56 AM
DIRep972's Avatar
Smarter than you
Dustin
It is tapped into the vacum line that runs from the FPR to the FMU.. I have a Garrett turbo and it doesnt have the port on the compressor..
Old Nov 23, 2001 | 10:00 AM
DIRep972's Avatar
Smarter than you
Default Re: im hitting just under .2bar.. somethings wrong, i have a few ideas (BluLuder)
im running the tial wastegate and I have a greddy boost gauge.. Im pretty sure its not the intercooler piping cause I made sure those were tightened like crazy but ill check it out.. I did change my exhaust manifold gasket too..
Old Nov 23, 2001 | 11:40 AM
jbsadler's Avatar
New User
If you get bored over the weekend, come over to my house while my car is still here and we can exchange parts untill we find out what the problem is..........jbsadler to the rescue!!!!!
Old Nov 23, 2001 | 03:27 PM
DIRep972's Avatar
Smarter than you
Default Re: im hitting just under .2bar.. somethings wrong, i have a few ideas (jbsadler)
Damnit I was bored all day today but im about to go out now.. Expect a call from me tomorow though..
Old Nov 23, 2001 | 05:17 PM
Dee's Avatar
Dee
you are taking the vacuum source from the wrong spot! Drill and tap a hole into the piping before the IC. Use a -6 stainless or 8mm rubber hose to connect the side of the w/g to the source. You should get full boost in all gears.
Read this post too.
gaundy22
Dec 6, 2015 08:40 AM
GSRswapandslow.
Mar 31, 2004 09:05 AM
aracer69
Jul 8, 2003 07:01 AM
queez
Jun 6, 2003 07:01 PM
eg2turbo
Dec 9, 2002 09:51 AM
