Help! How do you wire up a inline fuel pump?
Old Nov 23, 2001 | 06:39 PM
WykidEH's Avatar
Default Help! How do you wire up a inline fuel pump?
We're in the middle of putting a Turbo on a friends Civic SI w/a GSR swap and can't remember how to wire up the inline fuel pump. I think I can wire it into the under hood fuse box. . . . . right. . . . ? Thanks. . . ..
Old Nov 23, 2001 | 06:52 PM
chri5's Avatar
Default Re: Help! How do you wire up a inline fuel pump? (WykidEG6)
the fusebox you want to use is located underneath the the dash, near the drivers left leg. That is assuming that you still have it where it would be normally.
Old Nov 23, 2001 | 06:55 PM
Damon B.'s Avatar
Default Re: Help! How do you wire up a inline fuel pump? (Chris_Turbo)
Actually, on the Si it is under the passenger side, right above the ecu. Your talking about the fuel relay right? I looked for a couple of hours until I realized it was right above the ecu (under the kick panel on passenger side). Btw, why did your friend buy an Si just to swap out the motor? might aswell have bought a gsr, or lower model civic and swap.
Old Nov 23, 2001 | 07:05 PM
WykidEH's Avatar
Default Re: Help! How do you wire up a inline fuel pump? (CleanSi)
It's a '93 model year. . . . any one know how?
Old Nov 23, 2001 | 07:11 PM
chri5's Avatar
in that case, no clue
Old Nov 23, 2001 | 07:14 PM
Damon B.'s Avatar
Oh, I guess that makes more sense. Have you tried to find the fuel pump relay? If you can't find it under the driver's side, check the spot I told you to earlier. I wouldn't be supprised if it is in the same spot as mine is.
RICE POLICE SIP
Apr 21, 2010 03:26 PM
crxfreak1117
Aug 15, 2009 06:09 AM
on-site ej1
Apr 3, 2009 09:30 AM
EF8SIR
Mar 19, 2002 05:11 AM
echo999
Oct 15, 2001 05:00 PM
