will old gsr motor hold up on boost
Old Jul 14, 2004 | 05:09 AM
Teinman's Avatar
Default will old gsr motor hold up on boost
i just purchased a 96 gsr with 140k on speedo the car supposedly is own owner and has mobil one since he bought it all records of everything the supposedly has been babied all its life i say that to say this is it a good idea to turbo a gsr whith that many miles i was going to get it tuned and eveything
Old Jul 14, 2004 | 05:16 AM
m R g S r's Avatar
Default Re: will old gsr motor hold up on boost (Teinman)
Do a compression check and a leakdown test and that will give you your answer.
Old Jul 14, 2004 | 08:28 AM
patdemps's Avatar
Default Re: will old gsr motor hold up on boost (m R g S r)
If the numbers are good then boost it
Old Jul 14, 2004 | 08:30 AM
G
sh!t happens.
Default Re: will old gsr motor hold up on boost (patdemps)
boost it..gsr motors loveeeeee boost..
Old Jul 14, 2004 | 08:35 AM
b16sedan's Avatar
Default Re: will old gsr motor hold up on boost (G"UNIT)
If compression and leakdown numbers look good, go for it. My brother boosted his 94 LS with 180 thousand on the clock, drove it boosted for another 25K boosted without issue. When we tore it down it still had good compression and oil pressure, but we threw some new pistons and rods in it along with a VTEC head, I think the chassis has in the neighbourhood of 235 thousand miles on it now. These are very, very stout motors, as long as you take good care of them they'll last a long time.
Old Jul 14, 2004 | 09:53 AM
Mad Cow's Avatar
i think maybe you might should use some punctuation you will get your point accross faster and easier it will be nicer for people to read i say that to say this your motor will be fine
92GSREG
Jan 15, 2011 04:15 PM
Christopherian1982
Jun 14, 2008 10:57 PM
laocivic
Oct 24, 2007 07:25 AM
H.A.R.T B18C1EG6
Oct 4, 2004 10:18 AM
revtech01
Sep 19, 2004 09:12 PM
