Lower ball joint - Problem please help me
Old Nov 22, 2001 | 03:09 PM
Magick211's Avatar
Default Lower ball joint - Problem please help me
Ok the bolt on the lowet ball join has some messed up threads i guess because when i go to screw the crown nut on it it screws on part of the way then stops and the whole bolt turns.................what do i need to do
Old Nov 23, 2001 | 02:05 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: Lower ball joint - Problem please help me (CivicBoyZC)
If the threads look good, place a jack under the LCA and jack car up off the jackstands. This will force the balljoint to seat enough to hopefully stop spinning. Sometimes you need a impact gun to get the nut on if it still spins.
Old Nov 23, 2001 | 04:52 AM
Magick211's Avatar
Default Re: Lower ball joint - Problem please help me (Mista Bone)
K ill get it a try. Thanks for the reply man
kenzo42
Sep 5, 2013 05:45 AM
JDM_SOHC
12
Mar 29, 2006 05:44 AM
dj626
Oct 21, 2004 07:13 AM
tuphatt
11
Sep 15, 2004 12:10 AM
nugget8000
Aug 27, 2001 09:37 PM
