Zex Dry Kit Installation
Old Jul 13, 2004 | 09:39 AM
ZexyAccord's Avatar
Default Zex Dry Kit Installation
Hey everyone, I'm new here and I registered to get some help with my "Project"
I got a 1997 Honda Accord and recently i got a ZEX dry kit from ebay! All of the parts are seem to be here and in good condition. I will be installing the kit myself. SO I've got a couple of questions and hope to get some usefull info. First question, for those who are familiar with zex dry systems, there is a white wire that goes from the purple control unit to the TPS (throttle position sensor). How do I connect it to the TPS? DO I splice one of the wires? If yes? WHich color? I got red, green and yellow. I know there is a way to check it however i dont have the volt meter so i'll be just splitting wires. Second question, what is the fuel pressure regulator looks like? Is it this round maybe 1" in diameter thing next to the fuel rail on the left? PLease, any imput would be appreciated. THanks.
P.S. will the nitrous inject into throttle body if my arming switch in on but the pedal is not depressed? or does WOT will only work when the arming switch is on? I'm confused
Old Jul 13, 2004 | 11:18 AM
Black Ex Coupe's Avatar
the nitrous kit will only work when the switch is on and your going full throttle. the white wire is spliced in with a t-tap. i've never done the install on your car so i cant tell you which color the wire is.
Old Jul 13, 2004 | 11:23 AM
ZexyAccord's Avatar
Default Re: (Black Ex Coupe)
assuming that its red wire (ive been told by zex techs) whats a t-tap? what is it look like? is it like a vampire clamp that splits and connects two wires together?
Old Jul 13, 2004 | 11:27 AM
Default Re: (ZexyAccord)
thats what a t-tap looks like
Old Jul 13, 2004 | 11:58 AM
ZexyAccord's Avatar
he he I always used to call em Vampire clips! Dont ask! I'm retarded but yeah... Thanks for the input! Hopefully I wont mess it up and be spraying before the weekend!
Old Jul 13, 2004 | 12:04 PM
Beach Accord's Avatar
**** t-taps.......much resistance in these....always solder j00r connections!
Old Jul 13, 2004 | 01:02 PM
ZexyAccord's Avatar
Default Re: (Beach Accord)
so t-tap wouldnt work? It has to register at 4.6 volts to be considered Wide Open Throttle. Do you think that with t-tap I would loose that volts difference? It wont work?
Old Jul 13, 2004 | 03:46 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beach Accord &raquo;</TD></TR><TR><TD CLASS="quote">**** t-taps.......much resistance in these....always solder j00r connections!</TD></TR></TABLE>
Porsche will void warranty on any t-tab connect while they accept solder.
why? because if you solder it right, the connecting point is even stronger than the wire itself
t tab came loose overtime, connection is inferior than soldier
Old Jul 13, 2004 | 06:48 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZexyAccord &raquo;</TD></TR><TR><TD CLASS="quote">so t-tap wouldnt work? It has to register at 4.6 volts to be considered Wide Open Throttle. Do you think that with t-tap I would loose that volts difference? It wont work?</TD></TR></TABLE>
soldering provides a good solid junction and also allows the electricity to pass through with as little resistance as possible. If there is a voltage drop across the junction, your 4.6 volts might register incorrectly.
jeffhoe
Mar 26, 2010 09:28 PM
nitrofish420
Aug 5, 2007 10:59 AM
civic5435
Jun 16, 2005 08:24 AM
d16rice
Mar 22, 2005 05:14 AM
mk2
Jan 5, 2005 07:51 PM
