just got back from dyno
hi guys i just got back from the dyno here are my numbers (what do you guys think) 238 whp and 180 toq. That on 7lbs
my set up
b16 head
rev valve,springs and retainers
gsr cams
mild port and polish
skunk2 manifold
stock t/b
18a block
tpye r oil pump
gsr water pump
new oem timing belt
block gaurd
eagle rods
je pistons 20 over
arp head bolts
oem ls headgasket
gsr tranny
drage turbo kit
t3-t4e turbo
tail 35mm wastegate
greddy tpye s bov
big aftermarket fmic
2 1/2 down pipe
3 in inlet cat 2 2.25 outlet
2.25 tanabe racing med.
also runnin the dsm hack
walbro 255 fuel pump
no boost controller yet
and i had perfect a/f just a little lean at v-tec engament but other than that the a/f was perfect. And i was making power all the way to redline i think i need to raise the rev limiter a little higher the power nevered dropped off .
Modified by g2crx at 7:26 PM 7/12/2004
my set up
b16 head
gsr cams
skunk2 manifold
stock t/b
18a block
tpye r oil pump
gsr water pump
new oem timing belt
block gaurd
eagle rods
je pistons 20 over
arp head bolts
oem ls headgasket
gsr tranny
drage turbo kit
t3-t4e turbo
tail 35mm wastegate
greddy tpye s bov
2 1/2 down pipe
yeah you have a mildly built engine here that could definately take some more pounds of boost. i think the exhaust is really hurting you too
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic »</TD></TR><TR><TD CLASS="quote">hmm something is definitly wrong because my buddy made 190 whp and 180 torque on a mild build ls vtec</TD></TR></TABLE>
why would something be wrong?? those numbers are @ 7 psi. so what if your boy made that on ls/vtec...what does have to do with anything? the man has a b16a....the torque numbers are going to be significantly less then the whp made....
anyway..setup looks good......you should tune for more considering you have a built bottom
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit »</TD></TR><TR><TD CLASS="quote">
anyway..setup looks good......you should tune for more considering you have a built bottom</TD></TR></TABLE>
my bad....missed the b18a
madking411
71
Feb 2, 2011 04:53 AM
