just got back from dyno
Old Jul 12, 2004 | 10:16 AM
g2crx's Avatar
Default just got back from dyno
hi guys i just got back from the dyno here are my numbers (what do you guys think) 238 whp and 180 toq. That on 7lbs
my set up
b16 head
rev valve,springs and retainers
gsr cams
mild port and polish
skunk2 manifold
stock t/b
18a block
tpye r oil pump
gsr water pump
new oem timing belt
block gaurd
eagle rods
je pistons 20 over
arp head bolts
oem ls headgasket
gsr tranny
drage turbo kit
t3-t4e turbo
tail 35mm wastegate
greddy tpye s bov
big aftermarket fmic
2 1/2 down pipe
3 in inlet cat 2 2.25 outlet
2.25 tanabe racing med.
also runnin the dsm hack
walbro 255 fuel pump
no boost controller yet
and i had perfect a/f just a little lean at v-tec engament but other than that the a/f was perfect. And i was making power all the way to redline i think i need to raise the rev limiter a little higher the power nevered dropped off .
Modified by g2crx at 7:26 PM 7/12/2004
Old Jul 12, 2004 | 10:20 AM
PM-Performance's Avatar
Default Re: just got back from dyno (g2crx)
not too bad considering the exhaust set up and low boost.
Old Jul 12, 2004 | 10:24 AM
USDM 4G VTEC's Avatar
why do people always post their whole setup
but forget the PSI level they pushing
Old Jul 12, 2004 | 10:26 AM
g2crx's Avatar
Default Re: (USDM 4G VTEC)
my bad thats on 7lbs
Old Jul 12, 2004 | 10:41 AM
g2crx's Avatar
Default Re: (g2crx)
ttt
Old Jul 12, 2004 | 11:21 AM
Aludew5's Avatar
Default Re: (g2crx)
Looks good for just 7lbs. How about posting the actual graph with A/F ratios too?
Old Jul 12, 2004 | 11:34 AM
g2crx's Avatar
Default Re: (Aludew5)
im waiting to get the e-mail from the guys at exoticmotorsports cause there printer was down.
Old Jul 12, 2004 | 12:32 PM
g2crx's Avatar
Default Re: (g2crx)
ttt
Old Jul 12, 2004 | 12:39 PM
The Destroyer's Avatar
Default Re: (g2crx)
Looks like a VERY solid setup for the power you are making.
Old Jul 12, 2004 | 01:20 PM
Mr.DC2TurBo's Avatar
seems sort of low for LS/Vtec at 7psi. I was thinking more around 260+ but your exhaust might be the reason for the lower numbers.
Old Jul 12, 2004 | 01:34 PM
g2crx's Avatar
Default Re: just got back from dyno (Mr.DC2TurBo)
yea i was thinking of the same thing!
Old Jul 12, 2004 | 01:38 PM
alpha's Avatar
Turn the boost up and start making some more power Who did the "mild" head work?
Old Jul 12, 2004 | 01:54 PM
tyflip2's Avatar
Default Re: just got back from dyno (0x64)
yeah you have a mildly built engine here that could definately take some more pounds of boost. i think the exhaust is really hurting you too
Old Jul 12, 2004 | 02:26 PM
g2crx's Avatar
Default Re: just got back from dyno (tyflip2)
thanx guys going to the dyno this sat. with a boost controller so i should make alot more power.
Old Jul 13, 2004 | 06:46 AM
g2crx's Avatar
ttt
Old Jul 13, 2004 | 06:48 AM
get that Hondata from Jeff James and have him tune that pig. that ex is really holding you back though
Old Jul 13, 2004 | 06:53 AM
g2crx's Avatar
Default Re: just got back from dyno (itr206)
kool thanx i pmed him waiting for a reply fk it im running open down pipe
Old Jul 13, 2004 | 08:25 AM
wpgcivic's Avatar
hmm something is definitly wrong because my buddy made 190 whp and 180 torque on a mild build ls vtec
Old Jul 13, 2004 | 10:10 AM
Chillinit's Avatar
Default Re: (wpgcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wpgcivic &raquo;</TD></TR><TR><TD CLASS="quote">hmm something is definitly wrong because my buddy made 190 whp and 180 torque on a mild build ls vtec</TD></TR></TABLE>
why would something be wrong?? those numbers are @ 7 psi. so what if your boy made that on ls/vtec...what does have to do with anything? the man has a b16a....the torque numbers are going to be significantly less then the whp made....
anyway..setup looks good......you should tune for more considering you have a built bottom
Old Jul 13, 2004 | 10:37 AM
Chillinit's Avatar
Default Re: (Chillinit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chillinit &raquo;</TD></TR><TR><TD CLASS="quote">
anyway..setup looks good......you should tune for more considering you have a built bottom</TD></TR></TABLE>
my bad....missed the b18a
Old Jul 13, 2004 | 01:28 PM
g2crx's Avatar
ttt
Old Jul 13, 2004 | 01:56 PM
wpgcivic's Avatar
exactly...
Old Jul 13, 2004 | 02:42 PM
B18C1CYA's Avatar
good numbers, they might be low becuse his compression might be lower depending on his pistons, i already know it is lower because of the b16a head.
Old Jul 14, 2004 | 07:00 AM
g2crx's Avatar
Default Re: (B18C1CYA)
my comp. is 9.5.1
la001268
Jun 23, 2012 03:40 AM
madking411
71
Feb 2, 2011 04:53 AM
Spent
Oct 14, 2010 02:43 PM
ekay. jay
41
Jan 6, 2007 03:18 PM
Yellb16crxsi
Sep 19, 2004 05:10 PM
