What boost should i run
Old 07-10-2004, 07:07 PM
94delsol's Avatar
Default What boost should i run
i have a 94 delsol and here is my setup...what kinda boost could i run ?
HP Range?
B18C block with darton sleeves and GSR crank
Manley Connecting Rods - Hold 600hp
JE Pistons 9:1 Compression 81mm Bore w/ Rings
GSR Water Pump
GSR Oil Pump
New Rod and Main Bearings
New Thrust Washers
ARP head studs
Greddy Oil line kit
New Head Gasket
Drag 3 Turbo kit
440CC injectors
AEM fuel rail
XS fuel pressure regulator 1:1
Old 07-10-2004, 07:10 PM
Vice President/CEO
kKdARIAN's Avatar
Default Re: What boost should i run (94delsol)
umm.. what fuel managment? I hate these questions.. why do you have a motor built and not know what kind of HP your looking to put down?
Old 07-10-2004, 09:57 PM
Soccerking3000's Avatar
Default Re: What boost should i run (kKdARIAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kKdARIAN &raquo;</TD></TR><TR><TD CLASS="quote">umm.. what fuel managment? I hate these questions.. why do you have a motor built and not know what kind of HP your looking to put down? </TD></TR></TABLE>
agreed you shouldnt be looking ho much boost you can run you should set an hp goal
Luserkid's Avatar
Default Re: What boost should i run (Soccerking3000)
Try 10000 psi and let us know how it goes.
Old 07-12-2004, 06:09 AM
94delsol's Avatar
Default Re: What boost should i run (Luserkid)
hey thanks really, for all the good help
Old 07-12-2004, 12:11 PM
Rod.'s Avatar
they are right
Old 07-12-2004, 12:57 PM
HatchedGTI's Avatar
Default Re: What boost should i run (redturbocivic)
your most definitley gonna need at least an upgraded fuel pump
Old 07-14-2004, 04:01 AM
Default Re: What boost should i run (HatchedGTI)
i say you could run around 15-17psi max i think that is an estimate, i think yu could put down around 450 hp if it is TUNED CORRECTLY.
Old 07-14-2004, 06:59 AM
i my honda
Global Mod
White Smoke's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Soccerking3000 &raquo;</TD></TR><TR><TD CLASS="quote">i say you could run around 15-17psi max i think that is an estimate, i think yu could put down around 450 hp if it is TUNED
CORRECTLY. </TD></TR></TABLE>
Not with those 440's! Maby 320-360??
Old 07-14-2004, 07:08 AM
Zakar's Avatar
gunna need bigger injectors and fuel setup for sure
Old 07-14-2004, 07:13 AM
m R g S r's Avatar
Default Re: (MusclecarGuyhasHonda)
Maybe he is just going for the ultra reliable 7psi on a built motor? Well, reliable if it is tuned well
DOHC Vtec Turbo
07-26-2006 02:18 AM
94integragsr
06-15-2006 06:41 PM
alfee
01-28-2006 05:25 PM
KeyserSoze
07-13-2005 07:45 PM
t04ef
09-26-2001 02:07 PM
Quick Reply: What boost should i run
