f22a buildup or swap
Old Jul 10, 2004 | 06:16 PM
paidroe454's Avatar
Default f22a buildup or swap
i have an 1992 accord 2dr and i was wonder if i should get a nother f22a or try to find an f22b dohc. and does the prelud 5spd trans have closer gear ratio than me 5spd i have in my car now its a stock 5spd ?
Old Jul 10, 2004 | 06:34 PM
madd's Avatar
Default Re: f22a buildup or swap (paidroe454)
how much money do you want to put into this? what are you going to build it up for (NA, NO2, turbo)? what kind of gains are you wanting? either way it is a must to build up the bottom end to see any major power gains. this can be very costly! we'll probably need a little more info on what you are wanting out of this before we can give you our best opinions...the F22A depending on what "trim" is going to have around 140hp, but has a compression of ~8:1 which is great for and type of forced induction....whereas the F22B has around 160hp, but has a higher compression of ~9:1 (which you could bring down with thicker head gasket, pistons, etc...).
Old Jul 10, 2004 | 06:41 PM
paidroe454's Avatar
Default Re: f22a buildup or swap (madd)
i want an put you in the back of your seat motor im thinking turbo but not to wild it still has to be a dayliy driver to and i could find an f22a motor for a round $300.00 but i would like to build an sleeper to soy im not getting pulled over every time i go down the road and hush up some mitshu owners.
Old Jul 10, 2004 | 06:46 PM
madd's Avatar
well...most important thing with forced induction is fuel management...DO NOT SKIMP ON THIS AS IT WILL SAVE YOUR *** MONEY AND HEARTACHE! also, im going ahead and building up my bottom end. depending on how much boost you want to run depends on what you need to do. but, building your engine up will increase its life 10 fold...you wont be sorry with the money you spend on it. if you decide not to go turbo after installed new pistons/rods etc... you will atleast have the peace of mind that your engine will last a hell of a long time.
Old Jul 10, 2004 | 06:53 PM
paidroe454's Avatar
I want to go with an turbo but lagg and to much heat. yes i agre on a engin mangement system is a must and oil collier along with a few other things too.
Old Jul 10, 2004 | 07:05 PM
madd's Avatar
lag? lag isn't that bad if not really non-existent...you just don't pick a random turbo and slap it on! you pick the turbo that best suites your needs! certain turbos spool faster than others. i believe the t3/t4 starts to spool around 3500rpm. don't quote me on that though...as i believe i read that. i cant tell you too much about all the spool times since im not that far ahead. im focusing simply on building the bottom end. turbo parts will come around later winter or early spring. don't get ahead of yourself either...start with one thing and stick with and move on. it may sound dorky, but i write down what i want to do in stages. stage 1 being replacing such and such, or completing the bottom end. basically, give yourself some sort of "things to do list" to follow as it may help you focus on what NEEDS to be done (helps me at least). lets say you buy your misc. turbo parts and half *** build your engine and give up? who knows if you can sell the stuff and make your money back (depending on if new or used). buy what you need when you need (unless its a hell of a deal). don't rush things either! get a helms, haynes, or chiltons manual as it will be a must for anything you do yourself. i nice set of tools is a must along with torque wrenches (really important). make a list of ALL the parts you need over and over again...read everything you can read on turbos, engines, and forced induction in general. you have so many options to choose that it's not even funny. make your decisions based on what you want and what you have learned...not just because someone says so.
for some helpful info
http://www.howstuffworks.com
great place to learn how turbo works, and other car parts! hope this helps you out somewhat and good luck on your endeavor!
MyEGisBad
Jan 19, 2011 10:12 AM
SOHC_civic_si
36
Jun 6, 2008 08:18 AM
EJ8ona
Jul 13, 2007 07:13 PM
jdmstreethatch
Feb 5, 2005 09:21 AM
Arch-Angel
Jul 11, 2003 12:56 AM
