Help, no Vtec
My boss bought a h22 1996 civic. obd1 h22 into a obd2 car with a conversion harness and a chipped p28. Now when the kid had it, it pulled hard, and vtec engaged, but know, i dont know what he did. There is a VAFCII in there and i am watching my VTO and it says vtec is engaging, but, there is no switchover. I printed out the pinouts that i searched for already, and everything seems to be in the correct order except of one thing. On the C or D plug that plugs into the the conversion harness, there is a wire just jammed in there and i cant seem to find it on my pinouts. It is like c or d 25, i can take pics if needed, no digi today. I dont know what it could be. I was thinking maybe the soliniod was bad? how would i go about checking this. Any help is appriciated
install a VTEC light. If VTEC isnt working you should throw a code. But if your use to VTEC crossover youll start to not feel it anymore like you use to. Atleast that happened to me once. So now i have a light to make sure it works (and this is a GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">Check the oil level. </TD></TR></TABLE>
check oil....
check oil....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brakiss »</TD></TR><TR><TD CLASS="quote">i checked oil, top level</TD></TR></TABLE>
doesnt anybody read the replies? come on peoples, i really want to know how to test the noid
Cant you take the noids ground wire and hook it up to a power source, shouldnt it click? ground sounds wrong but a wire from the noid hooked to power will make it click...try that
1 sLoW hAtCh
31
Jun 1, 2006 11:35 PM
lVlemphizStylez
May 8, 2006 04:03 PM
