Oil squirters...Needed or not?
Old Jul 10, 2004 | 01:06 PM
99blusi's Avatar
Default Oil squirters...Needed or not?
I bought a block, and have the intent of building it. Pistons/rods...and maybe sleeves if my old motor holds out long enough for me to save the money. Anyways, I was looking around and noticed there aren't any squirters on the bottom...the holes are there, but they're physically missing from the bucket o parts that came with it. Do you think I need them or not?
Old Jul 10, 2004 | 02:10 PM
rioninja's Avatar
Default Re: Oil squirters...Needed or not? (99blusi)
For stock pistons, yes.
For forged pistons, no.
Old Jul 10, 2004 | 02:30 PM
earl's Avatar
You need them or you need to plug the holes they came out of or you will have no oil pressure.
Old Jul 10, 2004 | 03:35 PM
Muckman's Avatar
Moderator in Chief
Default Re: Oil squirters...Needed or not? (earl)
Def plug them if you dont have them but I like the idea of the oil squirters. It cant hurt.
Old Jul 10, 2004 | 04:04 PM
earl's Avatar
Default Re: Oil squirters...Needed or not? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote"> It cant hurt. </TD></TR></TABLE>Just like chicken soup when you are sick...it doesn't help but it cannot hurt
Old Jul 10, 2004 | 05:21 PM
Muckman's Avatar
Moderator in Chief
At the very least, wouldn't it help to cool the pistons?
Old Jul 14, 2004 | 10:44 AM
99blusi's Avatar
I think I may just pull the squirters off my b16a2 and put them on the b16a that I'm building. Not like I can run 2 motors at the same time anyways. couldn't hurt anything to have them in there.
Old Jul 14, 2004 | 10:52 AM
vtec.dc2's Avatar
if someone may explain, why are they necessary for stock pistons? and does it provide more lubrication/more stable oil pressure when removed with forged pistons?
Old Jul 14, 2004 | 10:55 AM
b18bturbo's Avatar
Default Re: Oil squirters...Needed or not? (vtec.dc2)
the primary reason is because the stock pistons are cast units and are not forged like the aftermarket. The reaons you want the oil squirters on cast is to keep the temps down.
Old Jul 14, 2004 | 11:52 AM
bigTom's Avatar
but at the same time it adds weight to the piston
Old Jul 14, 2004 | 12:01 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Oil squirters...Needed or not? (ek9t)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9t &raquo;</TD></TR><TR><TD CLASS="quote">but at the same time it adds weight to the piston</TD></TR></TABLE>
Old Jul 14, 2004 | 12:30 PM
tgreaves's Avatar
The oil squirters aren't on the pistons, they attach on the block under the pistons..
Old Jul 19, 2005 | 10:47 PM
SnOOpY-NO's Avatar
Default Re: Oil squirters...Needed or not? (tgreaves)
But they are squirting on the pistons from underside, and that adds extra resistance when the piston is going down...
Also explained as extra weight...
Old Jul 20, 2005 | 05:58 PM
T4eg's Avatar
Default Re: Oil squirters...Needed or not? (SnOOpY-NO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SnOOpY-NO &raquo;</TD></TR><TR><TD CLASS="quote">But they are squirting on the pistons from underside, and that adds extra resistance when the piston is going down...
Also explained as extra weight... </TD></TR></TABLE>
correct
juniestyle
May 23, 2007 02:32 PM
92TypeR
13
Feb 26, 2005 11:18 AM
lke2drvgsr
Nov 26, 2004 08:04 PM
HaTcH_BmX
Jul 27, 2004 12:30 PM
sweet
Apr 24, 2003 10:29 AM
