Would this cam be good for my turbo accord? have specs
Well i have been reading to make sure this new cam i put in isnt going to have adverse affects on my turbo installation or if they will work well together. i was reading a little bit about turbo cams in here but it was pretty much all about teggys, and i have a 95 accord lx. k, my cam is a Gude performance, they claim that the cam does not affect stock idle, and it is designed to work best with stock valve springs. here are the other specs from there site.
Intake LIFT - .405 DURATION - 228
Exhaust LIFT - .402 DURATION - 228
i'll be boosting 6psi, t25 turbo and intercooler. i also have a aem adjustable cam gear. so, do you guys think this cam will help or hurt my cars performance with the turbo? any help or opinions at all are appreciated!
Re: Would this cam be good for my turbo accord? have specs (misfitty)
anyone? even if you dont have experience with accords does that lift and duration sound good for 6psi of boost?
get a delta cam regrind before a gude regrind. contact them at delta-cam, they have a site, but id suggest talking to them via phone for best results. great people. great regrind.
edit, gude is a nightmare company
after i posted that i looked at there website, and they are reground stock cams. i was just confused because they send you a whole new cam then you send in your old one after. they then regrind that one and sell it to someone else, so your getting a regrind, but this way it gets to you faster rather than waiting for the machining to be done.
