d15b VTEC swap ~ HELP!!!
Old Jul 10, 2004 | 10:27 AM
EFing_bmxED's Avatar
Default d15b VTEC swap ~ HELP!!!
I just bought a d15b vtec motor for my 94 CX, and I know I have to swap the entire wiring harness over, but do I have to get one for a 92-95 Si or EX, or could I get one from an EK like for instance a 96 EX? and what computer do I use? my friend said something about a P72 from an integra would fit, but all this stuff is too complicated so I'd appreciate any advice!
Old Jul 10, 2004 | 10:29 AM
AzntaggeR's Avatar
TSPeed Factory
Default Re: d15b VTEC swap ~ HELP!!! (streetracer859)
try and get an obd1 harness. if you get one out of an EK you're going to have to deal with a bunch obd2 BS and a lot of the plugs won't even match up with your motor.
Old Jul 10, 2004 | 11:00 AM
egizzle8
Guest
Posts: n/a
Default Re: d15b VTEC swap ~ HELP!!! (AzntaggeR)
Just get a EX or 92 dx harness cause they came prewired for vtec I believe.
Old Jul 10, 2004 | 11:03 AM
Default Re: d15b VTEC swap ~ HELP!!! (egizzle6)
the DX did?
drewbie*'s Avatar
you want the p08 ecu for best performance, or something chipped to a custom program.. if you want the po8 ecus i have them.
Old Jul 10, 2004 | 11:14 AM
Default Re: d15b VTEC swap ~ HELP!!! (Drew95eg)
How much $$?
Old Jul 13, 2004 | 10:24 AM
drewbie*'s Avatar
$115 shipped.
and you dont need a whole new harness...
just follow this
https://honda-tech.com/zerothread?id=724252
Old Jan 9, 2005 | 04:52 PM
rexizbest's Avatar
alright, I have a 95 ex harness that i planned on using for my crx. Im swapping out my stock dx motor (dpfi) for a d15b vtec. However, none of the plugs on the ex harness match up to the wiring that goes through the firewall. Do i need that part of the harness too? Is there a conversion harness or anything. Please help!
Old Jan 9, 2005 | 10:27 PM
Yumm Tum Yummm's Avatar
p-28 ecu works perfect vtec at 4800 redline at 7200
Old Jan 9, 2005 | 11:52 PM
ej1 pilot's Avatar
Default Re: d15b VTEC swap ~ HELP!!! (EJ_FaNaTiK_22)
just use your stock harness i used mine from my 93 cx
Old Jan 10, 2005 | 02:13 AM
menkio's Avatar
Default Re: d15b VTEC swap ~ HELP!!! (Art In Motion)
go with the 92 or an ex harness, nice and clean, tape it up, etc, and grab yourself a virgin p28. Good luck on your swap, and don't forget to clean/paint that engine bay, engine out makes it easyer
egvtec
Aug 18, 2008 08:20 PM
Myh4tch
Jun 14, 2005 06:56 PM
AutoBoxEng
Mar 5, 2005 01:24 PM
pheen0m
Jan 17, 2005 12:57 AM
yokalryder
Jan 13, 2002 04:23 PM
