sohc swaps
sohc swaps
I am swapping my CX motor for an EX motor in my 92 hatch, i keep overhearing that they dont swap right over. Doesnt an EX motor bolt right in, i know to get the computer but what else might i need to make this a quick and easy job?
Re: sohc swaps (yokalryder)
it is a direct swap. a wiring harness from an ex or si would be a big help. are u changing just the motor or doing the entire swap including the trans? i would get everyting from the ex: trans, ecu, harness, intake manifold, etc...
Re: sohc swaps (b20bastard)
the internal harness (dash, ecu) already has the vtec wiring in 92s only, the external (engine bay) doesn't.
so you need to plug in the engine bay harness from a 92-95 Si/EX and just plug in the P28. no custom wiring needed.
[Modified by 95CivicSi, 5:50 PM 1/11/2002]
New User
man it works just fine!! i put a ex/si motor in my vx hatchback. to make things a little easier get a 92-95 ex/si motor.. im not sure about the newer style ex motor d16y8.. you can use your vx ecu but it would suck! if you get the motor get the ecu, and tranny. you can use your stock tranny but the gear ratios are different.. later
[Modified by v-tec crx, 3:52 PM 1/11/2002]
New User
yeah you will be ok with the same year ex motor and ecu.. try to get the tranny too because it will run better with a ex/si tranny then a cx tranny.. the cx tranny the gears are long!!
