5 lug onversion on eg problem
Old Jul 9, 2004 | 08:31 PM
allmotor94hatch's Avatar
Default 5 lug onversion on eg problem
did a 5 lug conversion on an eg and it just seems like my rear brakes are not workin like they should.. i did the full knuckle assembly and thats it...just wonderin if there is anything i should of done and what such as a type r power brake booster or what...it was a cx before hand if that helps
Old Jul 9, 2004 | 08:34 PM
JDM R's Avatar
Default Re: 5 lug onversion on eg problem (allmotor94hatch)
prop valve maybe? did you bleed the brakes, check the cables and even check the condition of the calipers?
Old Jul 9, 2004 | 08:36 PM
Default Re: 5 lug onversion on eg problem (JDMar)
yeah i was thinkin the prop valve but thats in the booster i thought so i would need a type r one i suppose. brakes are new and bled fine..did seem like the rotors before were rippled possibly hung calipers??
Old Jul 9, 2004 | 08:56 PM
JDM R's Avatar
i would suggest gettin a bigger MC/booster to help the pedal feel, so youre sayin you already have a prop valve installed? im confused by your post
Old Jul 9, 2004 | 10:41 PM
b00sted93Hatch's Avatar
In what way are they not working? Like parking or while driving? Nice sn btw haha
Old Jul 9, 2004 | 10:42 PM
hatchi's Avatar
Prop valve is located in the center of the firewall not in the booster
Old Jul 10, 2004 | 11:42 AM
Default Re: 5 lug onversion on eg problem (allMotor93Hatch)
i mean i cant acutally tell it just seems that they are not wearing as much as they should and my front brakes seem to be doin all the work..and as far as the prop valve should that be from like a type r or even an si somethin that had rear disc
Old Jul 10, 2004 | 11:47 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
i had a 15/16 on my CX when i had the 5 lug on there......do you feel the added weight????
https://honda-tech.com/zerothread?id=915556
the brakes are the shyt by all means......
hialeahzbg
20
Apr 29, 2006 06:01 PM
jimmhatch
Jun 25, 2005 06:31 AM
jdmcx
Jul 28, 2003 10:21 AM
Mugen_R
Jun 20, 2001 09:43 PM
