k series motors and hybrid.
Old Nov 19, 2001 | 08:29 AM
rainforest's Avatar
Default k series motors and hybrid.
so when are going to figure out how to do these swaps. I cant wait till someone brings me a new 2002 civic si and say put a k24 crv block on this and a rsx type s head on this bitch. so hey lets get this started.
Old Nov 19, 2001 | 08:40 AM
ImportechPerformance's Avatar
Default Re: k series motors and hybrid. (rainforest)
ha ha! lol !!!! that would be nice. why dont you try it first. Try finding a wrecked k24 crv. let us know how it turns out.
Old Nov 19, 2001 | 09:19 AM
IntegraTypeRice's Avatar
Default Re: k series motors and hybrid. (MrPimpon)
I was thinking the same thing when I saw the CRV has 160 ftlbs of torque! Maybe you could throw that motor into the 01 Civic?
Old Nov 19, 2001 | 10:35 AM
HXMan's Avatar
I am sure it will be done soon. If I lived where there were a ton of honda tuners with hookups, I would personally attempt it.
Since the new K24 CRV block is i-VTEC as well I wonder if the rsx type-s head will bolt on no problem? Maybe running external oil lines for VTEC will be a thing of the past?
Anyone know if you could bolt a K24 in a 2001 Civic? The new crv and the 7g civic share the same chassie.
Old Nov 20, 2001 | 05:15 AM
Daemione's Avatar
Default Re: k series motors and hybrid. (HXMan)
I'd say the K24 block is more trouble than it's worth. Sure, displacement is nice, but when it comes with a 99 mm stroke . . . . .
Fat chance of seeing anything over 7,000 rpms.
Best possibility that I can see right now is a Type S head on the Civic Si. Too bad the new Civic hatch isn't much lighter than the RSX, though.
Old Nov 20, 2001 | 07:59 AM
HXMan's Avatar
Default Re: k series motors and hybrid. (Daemione)
Yea, this is true. But I think it has a larger bore, so how about destroking it with a K20 crank?
The type-s head should have been on the new Si in the first place!
Old Nov 20, 2001 | 08:16 AM
rainforest's Avatar
where did you get the specs on the motors.
Old Nov 20, 2001 | 10:18 AM
Daemione's Avatar
The K20c (rsx-s) is 86mmX86mm, and the K24 (cr-v) is 87mmX99mm. Destroking it with a K20c doesn't seem worth it for just 1 mm of bore. You could probably get that out of the stock K20 block. But I don't think there's too many pistons available for overbored K-series, and I doubt you'd want to use CR-V pistons.
I'm curious as to what the differences are between the base RSX (K20a) & Civic Si (engine code?). I believe power output is slightly different, which leads one to believe that they're not exactly the same. It'd be nice if the Civic at least came with the type S bottom end (higher compression pistons, beefier rods).
Another possibility I noticed lies within trannies . . . . the 5-speed CR-V final drive is 4.765. RSX-S is around 4.36, I think, which would be a significant jump. Assuming the trannies are similiar enough for it to be a possiblity, that is.
I got the K20a/c engine specs from sport compact car, and K24 specs from some generic web source (yahoo/google).
Old Nov 20, 2001 | 06:44 PM
HXMan's Avatar
Ok, so the destroking thing is pretty pointless.
I didn't think there was a difference between the base RSX engine and the New Si engine? What is the power difference?
The FD differences is interesting.
Old Nov 21, 2001 | 05:52 AM
Daemione's Avatar
Yeah, I seem to recall that the Civic Si & base RSX made their peak numbers at slightly different RPM's. Which could be just different tuning of the iVTEC. Fuzzy memory, though, I could be wrong.
I'll look around & try to figure out where I saw that.
4gen
May 15, 2007 11:30 AM
1badda
14
Oct 1, 2004 05:18 PM
Samsonite
Nov 4, 2002 05:24 AM
gsr camel
Dec 1, 2001 02:27 PM
SlipAngleX
Jun 26, 2001 08:46 PM
