Help please (LCA seized)
Ok well the driver side rear LCA came off like butta'
Then i got to the passanger side
The bolt the holds the LCA to the frame is seized, the pin that sits in the bushing is seized to the side of the frame. I have no idea what to do... any help would be appreciated . thank you
try to see if their is any part of the bolt that you can get a hold on with a visegrip and try to screw it out, if not try to get your hands on a heavy duty drill and try and drill it out. or as stated above toch time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid Hatchback »</TD></TR><TR><TD CLASS="quote">oh beleive me its Soaked in PB
PB isnt going to unattatch two peices of metal ....errr its like there welded to each other
Hmm... time for an air chisel.
</TD></TR></TABLE>Hmm... time for an air chisel.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4drEF »</TD></TR><TR><TD CLASS="quote">
Hmm... time for an air chisel.</TD></TR></TABLE>
no air chisel in my tool box
ok let me clarify, the bolt is turning and wants to come out but since its stuck to the side the whole 'U" bracket bends and im afraid of breaking it,
i would think, once you have sawed the bolt on both sides, the head should come right off using a rachet since its not being held in...and on the other side use some vice grips and turn it bit by bit...
drill will take too long and such...but then again i never had to do this and im taking a logical approach to this...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stk crx »</TD></TR><TR><TD CLASS="quote">IMPACT IT OFF...You can fix the broken or bent peice later</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator »</TD></TR><TR><TD CLASS="quote">saw both sides of the bolt then turn out the bolt when the lca is dropped...
worked like a charm
</TD></TR></TABLE>worked like a charm
akdrag
23
Jun 26, 2008 06:55 AM
. o 69 o .
Feb 28, 2004 02:29 PM
mattharper
Dec 8, 2003 08:33 PM
