Had my test pipe installed...and check engin light comes on
Old Nov 17, 2001 | 01:25 AM
Pure R Racer's Avatar
Default Had my test pipe installed...and check engin light comes on
I just installed my test pip today....drove it for like 50 miles and then the check engine light comes on....anyone knows why?...is it due to the O2 sensor?
Old Nov 17, 2001 | 01:26 AM
ITR111's Avatar
New User
Default Re: Had my test pipe installed...and check engin light comes on (Pure R Racer)
yes
OBD2 sensors
Old Nov 17, 2001 | 01:32 AM
Default Re: Had my test pipe installed...and check engin light comes on (ITR111)
so what should i do to sovle the problems?...will it come back on after i reset the ecu?
Old Nov 17, 2001 | 01:39 AM
Hybrid ctr's Avatar
yes it will
Old Nov 17, 2001 | 01:43 AM
Default Re: Had my test pipe installed...and check engin light comes on (Hybrid ctr)
so the engine check like will always be on?....but that's not a problem right?
Old Nov 17, 2001 | 03:24 AM
Type Goch's Avatar
New User
so it doesnt a bung for the 2nd O2 sensor?
Old Nov 17, 2001 | 03:55 AM
bodykit=rice's Avatar
Default Re: Had my test pipe installed...and check engin light comes on (Type Goch)
why don't you jump the jumper and find out what code it is then diagnose your problem.. your iacv could be throwing a light or vtec isn't hooked up and it's throwing a light (not saying that's the problem) but just don't jump to conclusions thinking it's the o2 sensors...
Old Nov 17, 2001 | 05:44 AM
TypeR0149's Avatar
you can put the O2 sensor in the cabin, so you wont throw the light, when that light goes on you lose 2 deg timing, thats what i heard from acura
Old Nov 17, 2001 | 07:39 AM
Comtechgsr2000s's Avatar
New User
Default Re: Had my test pipe installed...and check engin light comes on (Vegeta)
This is what you can do but you may have to do this every 3 months.
Take tin foil and wrap your o2 sensor then wrap it with metal wire.
Place the tin foil back in the test pipe and reset your ecu. You light will not come back until your tin foil burns away.
Old Nov 17, 2001 | 08:50 AM
Default Re: Had my test pipe installed...and check engin light comes on (Mugenblkgsr2000)
thx guys
Old Nov 17, 2001 | 08:54 AM
Dr Pooface's Avatar
Get a high flow cat.
Old Nov 17, 2001 | 01:38 PM
e's Avatar
e
New User
Ive done that;kind of a pain in the ***;having to keep taking it out and replacing the foil,.on a early post 1 guy suggested plugging the second 02 sensor in the bung in the header,and wrapping the first o2 sensor out of the way,im thinking of trying this, has any body had any luck,....
Old Nov 17, 2001 | 01:53 PM
Default Re: Had my test pipe installed...and check engin light comes on (blythzithe)
what will happen if i jsut let the light stays on?
Old Nov 17, 2001 | 02:00 PM
Type Goch's Avatar
New User
would you run into limp mode?
ic108's Avatar
New User
if you put some cat material aroun the O2 sensor it will work without throwing a code. but that means that you have to hollow out your cat to get some material. or you can do a P28 ECU. thats what i did. its up to you
Old Nov 28, 2001 | 06:33 PM
zip's Avatar
zip
Try this new product out: http://forums.clubsi.com/ubb/Forum12/HTML/009048.html
kelvinchau25
Jan 11, 2006 09:10 PM
Spazzua15
Dec 14, 2005 06:21 PM
951dc5
May 29, 2005 04:39 PM
94civicx
Aug 7, 2002 03:50 PM
sivicman
May 15, 2002 01:17 PM
