This is weird...see if it makes any sense to you...
Old Jun 24, 2004 | 04:57 PM
SpoolnG2's Avatar
Default This is weird...see if it makes any sense to you...
So i'm driving my car and jump on it...runs like a champ...again..again..again. Then after I do it a few times and i go to do it again, it misfires and doesnt pull strong to redline. Sounds like an ignition problem. Coil ? Ignition Box? Wires? Cap? Rotor? If it is one of those though, how come it runs good and then all of a sudden runs like ***. The Coil/cap/Box are MSD and are all about 3 years old. Maybe time for a new coil? what do u guys think?
Old Jun 24, 2004 | 05:14 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: This is weird...see if it makes any sense to you... (SpoolnG2)
Sounds like....foul spark plugs...!!!
Old Jun 24, 2004 | 05:24 PM
SpoolnG2's Avatar
Default Re: This is weird...see if it makes any sense to you... (NVturbo)
why would it run fine and not misfire....then all of a sudden just start to misfire?
Old Jun 24, 2004 | 05:34 PM
GEN2TEG's Avatar
I had the same problem a while back and turned out it was the damn MSD wires. Not sure what wires your running but go with stock Honda.
Old Jun 24, 2004 | 07:41 PM
SpoolnG2's Avatar
Default Re: (GEN2TEG)
yeah, i'm running MSD wires. Maybe I should try out some stockers? Anything else u guys can think of? Probably also just needs to be tuned. What exactly was yours doing with the msd wires?
Old Jun 24, 2004 | 07:44 PM
INVALID's Avatar
From: Why so you can pretend like youre interested, FL/OK
With the upgrade to the ignition, wouldn't the smaller wires defeat some of the purpose of having the ignition and cap?
Old Jun 24, 2004 | 07:50 PM
SpoolnG2's Avatar
Default Re: (INVALID)
i dont think you would lose that much really. Other then the plugs any other ideers?
Old Jun 24, 2004 | 08:35 PM
INVALID's Avatar
Default Re: (SpoolnG2)
Have you inspected your spark plugs? If you do still have the stock wires laying around, no sense in not trying it out to see if the car runs fine.
Old Jun 24, 2004 | 08:45 PM
tegedrex's Avatar
had this same problem just pulled the plugs and went a step colder and .025 gap
Old Jun 24, 2004 | 09:02 PM
SpoolnG2's Avatar
Default Re: This is weird...see if it makes any sense to you... (tegedrex)
you know what, you may be right. I just went out there and regapped the plugs again and it seems like the gap got bigger from last time. Right now i'm running a BKR7E with a .029 - .030 gap. Running 13.2psi
what plug should i run? Is it possibly its getting so hot in there the plug is expanding when heated after a while, and then the gap goes to big and therefore runs like ***?
Old Jun 24, 2004 | 09:11 PM
tegedrex's Avatar
Thats what I got now, and went to .025. Im only pushing 9psi but made 312hp w/ them. If they go I get the 9's next
Old Jun 24, 2004 | 09:14 PM
SpoolnG2's Avatar
what plug are you running? you think its possible for the plug to expand like that after its heated so many times?
Old Jun 24, 2004 | 09:27 PM
tegedrex's Avatar
im runnin BKR7E now, and when I first put thise in I was at .030 and missing under boost so I went down to .025 and fixed my prob.
Old Jun 24, 2004 | 09:30 PM
SpoolnG2's Avatar
maybe the plug just needs to be gapped smaller...or it needs a colder plug? I'm not sure.
Old Jun 24, 2004 | 09:39 PM
tegedrex's Avatar
ight as well try a smaller gap before going to buy colder plugs, I think that should solve the problem
Old Jun 24, 2004 | 10:38 PM
ImportHatch's Avatar
maybe the dist? My car did that when my dist seal was leaking.
Yager-
Old Jun 25, 2004 | 07:01 AM
SpoolnG2's Avatar
Default Re: (ImportHatch)
no, not the distributor. I regapped the plugs last night and took it for a ride and it ran good. Maybe the plugs just need to be gapped smaller...the only thing i can really think of.
Old Jun 25, 2004 | 07:23 PM
NVturbo's Avatar
O.G. triple O.G.
hey..if your car starts sounding like a "helicopter" and is unable to make boost...( i had this problem before )...it is your wires!!...I had MSD wires once...replaced them with stockers..and problem was resolved.
Modified by NVturbo at 9:53 PM 6/28/2004
Old Jun 26, 2004 | 12:09 AM
Boltz's Avatar
Default Re: (NVturbo)
Didn't know you had your car on the street josh, hows it running? Well besides the obvious problem that this thread states.
justin
Old Jun 26, 2004 | 03:55 AM
nevin's Avatar
i vote ignitor
B-outAteam
Sep 6, 2009 06:38 AM
95civickid
11
Jan 28, 2007 06:10 AM
Mr HYDE
Jan 7, 2006 01:33 PM
Jet Black
Apr 29, 2004 11:15 AM
Acura_I-RS
Jun 6, 2002 03:57 PM
