Greddy CEL after WOT...please help
anyone get this ....after i hit full boost i get a check engine light that pops on...if i turn the car off it goes away till the next time i hit full boost for a couple seconds..
setup
d16z6
p28 ecu
E-manage
15g greddy turbo
1g intercooler
1g bov
the emanage doesnt throw a code only the car does....i know other people have this problem does anyone know what it is
setup
d16z6
p28 ecu
E-manage
15g greddy turbo
1g intercooler
1g bov
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 »</TD></TR><TR><TD CLASS="quote">i bet your throwing a map code. If your not using a missing link the map sensor is reading boost. most likely thats your problem
I agree. Either that or Code 16 injector failure code. Those are the 2 common ones with the blue box or Emanage.
can i use the missing link with the emanage since the emanage works off the map....also the emanage doesnt throw any codes just the car and its still pulls hard when the code is on..even thought i dont like to push it with it throwing the CEl
i was told by other people that the code is a "Too Rich" code....i guess its better then a too lean code....The car seams to run fine with it on and the E-manage still is displaying the green light...so i think it will be okay...
any other thoughts
any other thoughts
no one is going to help you unless to give us the code.
your pissing me off by bumping this thread up.
next time you bump this thread up with no code I'm gonna slap you with my dick
The emanage will not show any ECU code dude. If your check engine light is on that is noooo good. Check the code. If you don't know how go to http://www.c-speedracing.com and look there.
