Need Help with CEL
Old Mar 26, 2003 | 09:04 AM
Bspec18's Avatar
Default Need Help with CEL
The code is for the MAP Sensor: I'm boosting 9.7psi but hardly get there without a code. At first i was running fish tank valves but that was throwing codes so i switched to the missing link it worked great for awhile but still i have problems. If anything im also thinkin it might be fuel since im always running rich. Or maybe the missing link is defected ? or has my map sensor gone bad ? the CEL comes on after about 5-6 psi
Old Mar 26, 2003 | 09:15 AM
Bspec18's Avatar
Default Re: Need Help with CEL (Bspec18)
bump
Old Mar 26, 2003 | 09:41 AM
b16ahybrid's Avatar
the map sensor is seeing boost thats why it throws a code....
Old Mar 26, 2003 | 10:20 AM
Daniel's Avatar
yeah, you could have a bad missing link. The missing link is supposed to block off the map sensor voltage from going to the ECU. if you're getting a code for it--which is a 3, no?--then it's not doing its job. What's your complete fuel setup?
Old Mar 26, 2003 | 11:04 PM
ZentraediEK's Avatar
Default Re: Need Help with CEL (Daniel)
bump...I'm having the same problem, have gone through 3 missing links and 2 map sensors and I still get the Damn Code 3...please help us out.
Cimburke23
Sep 13, 2004 05:23 PM
khmboostedeh2
Aug 27, 2004 09:17 AM
kaj
Sep 27, 2003 09:36 AM
platinum00
Jul 25, 2003 09:16 AM
