Water in Trunk
Old Jun 24, 2004 | 12:31 PM
cdntegintx's Avatar
Default Water in Trunk
I have a puddle of water in my trunk that seems to be coming in from around the taillights. The water isn't going in the taillights, just heading in the trunk. The gaskets around the lights look okay, I'm not sure what else I can do to stop this. Has anyone else had this problem?
Old Jun 24, 2004 | 12:48 PM
milo's Avatar
Default Re: Water in Trunk (cdntegintx)
replace the gaskets anyway... it worked for me
Old Jun 24, 2004 | 12:49 PM
fstassgsr's Avatar
yeah i have had that prob. since i bought my car 3 yrs ago. still can't figure out where its coming from so if you figure it out let me know.
Old Jun 24, 2004 | 12:50 PM
b17integra's Avatar
replace the gaskets they get old over time. even though the look fine. the gasket just wears out over time. that's what i did
Old Jun 24, 2004 | 01:15 PM
B18 CYA's Avatar
the water in ur trunk is from the sunroof drain tubes in your trunk. take off the panels in ur trunk and u will see a tube on each side that comes out near your back quarterpanel... it probably just got a little loose or came out and dumps the water in ur trunk...
Old Jun 24, 2004 | 01:45 PM
Kendall's Avatar
I've seen this many times. It always ends up being the tailight gasket. As for the sunroof drain tubes, I've never seen a case of them causing a leak.
Old Jun 24, 2004 | 01:59 PM
crawdad689's Avatar
Default Re: (Kendall)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall &raquo;</TD></TR><TR><TD CLASS="quote"> It always ends up being the tailight gasket. </TD></TR></TABLE>
I second the notion
Old Jun 24, 2004 | 02:16 PM
Ditdogs's Avatar
drill alittle hole in your trunk and let it drain out
Old Jun 24, 2004 | 05:15 PM
seer_claw's Avatar
Default Re: Water in Trunk (Ditdogs)
Go to http://www.team-integra.net. They have a nice article on all the ways water can get into your trunk and how to fix it.
Old Jun 24, 2004 | 05:34 PM
dellanooch's Avatar
Default Re: Water in Trunk (seer_claw)
Oh man, awesome thread - I was having the same problem with my '97.
Old Jun 24, 2004 | 07:24 PM
Ricky Rojales's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ditdogs &raquo;</TD></TR><TR><TD CLASS="quote">drill alittle hole in your trunk and let it drain out </TD></TR></TABLE>
Worked for me.
Old Jun 24, 2004 | 07:45 PM
Integra4lyfe's Avatar
Default Re: Water in Trunk (=p)
gasket
itsnotfast
15
Jan 1, 2010 06:28 AM
dc2teg808
Mar 14, 2009 12:38 AM
foomashoo
Dec 12, 2004 03:48 PM
.ShawnD.
Apr 26, 2004 10:33 AM
93si
Jan 4, 2004 12:20 AM
