Engine Starting
Old Jun 24, 2004 | 12:07 PM
QuadSquad'R's Avatar
Default Engine Starting
Seeking any opinions or advice on starting an engine that has not been used in almost 5 years. The specifics on the car: 92 Honda Prelude Si (Car was in a minder fender bender and stored ever since) Already acquired all the necessary components to restore car so any advice before i proceed would be greatly appreciated!
Old Jun 24, 2004 | 12:45 PM
JimBlake's Avatar
Default Re: Engine Starting (QuadSquad'R)
Search, I've seen something like this not too long ago...
Take off valve cover, check out timing belt.
Take out all sparkplugs, put a little oil in each cylinder, turn over by hand to make sure everything turns OK.
Crank with starter to circulate oil. Maybe drain & put new oil in.
Put plugs back in & start it.
Change oil, antifreeze, brake fluid, & whatever else you can think of.
Make sure the brakes work before you actually drive it.
Look for those other threads, I've probably forgotten some.
Old Jun 24, 2004 | 08:02 PM
Default Re: Engine Starting (JimBlake)
Thanks for the assistance! I will search for the related threads just incase we missed something!
JDMAF
12
Feb 2, 2011 11:02 PM
x justin
Dec 3, 2006 12:19 PM
Tad
Jun 25, 2005 08:56 PM
DC2fanboy
Feb 16, 2004 09:08 AM
s30lee
May 18, 2002 03:24 PM
