california smog(search didnt answer my ?)
Old Jun 24, 2004 | 11:00 AM
bigbacon2's Avatar
Default california smog(search didnt answer my ?)
ok my question is i have a 92 hatch with a 97 ls motor in it. everything for smog is hooked up on the motor. when i went to a normal smog place they went to run the test then it printed out a paper that said must see smog referee center. i have heard i will fail at a ref because the year of my motor. i need to kno if i iwll pass or not. the first guy said my car submitted clean emissions but it had to be seen by a ref. any help wouldbe appreciated thanks.
Old Jun 24, 2004 | 11:13 AM
13DevilsCamry's Avatar
Default Re: california smog(search didnt answer my ?) (bigbacon2)
You will need to get it certified. Here are the things that I know that you need to have in order to get it certified.
1. it has to be 92+ motor
2. All smog and emissions have to be included
3. You need to pay like $35 to get a tag that says that it's smog legal
4. Can't be a JDM motor, Has to be USDM
Hope this helps. I know a couple of people who did swaps and got a DOT approval on their firewall.
Old Jun 24, 2004 | 11:19 AM
mario82686's Avatar
From: Between San Diego and the OC, SOCAL, United States
Default Re: california smog(search didnt answer my ?) (13DevilsCamry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 13DevilsCamry &raquo;</TD></TR><TR><TD CLASS="quote">
4. Can't be a JDM motor, Has to be USDM</TD></TR></TABLE>
I thought JDM motors can be BAR certified.
Old Jun 24, 2004 | 11:30 AM
Marauder's Avatar
Default Re: california smog(search didnt answer my ?) (mario82686)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario82686 &raquo;</TD></TR><TR><TD CLASS="quote">I thought JDM motors can be BAR certified.</TD></TR></TABLE>
I believe they can be, as long as you use all of the USDM smog equipment.
Old Jun 24, 2004 | 01:05 PM
mario82686's Avatar
JDM 4 LIFE y0!!!
Old Jun 24, 2004 | 01:09 PM
eg6sir-s's Avatar
Default Re: (mario82686)
you must retain the stock uspec 97ls ecu and all smog equipment for that year motor...this has to be done the same if it were using a jdm 97ls motor.
Old Jun 24, 2004 | 02:23 PM
bigbacon2's Avatar
Default Re: (eg6si)
i am using a 97 usdm ls and the ecu and everything is the right one and everything else is hooked up for smog. the only thing i have heard tho is that it will not pass because it is an obdII motor going into an obdI. i heard there is no way to pass an obdII motor off in an ObdI car. any comments would help thanks
Old Jun 24, 2004 | 02:25 PM
mario82686's Avatar
So if you have a jdm b16 you would still need a USDM ecu?
Old Jun 24, 2004 | 03:05 PM
emoney9's Avatar
yes...everything has to be usdm
Old Jun 24, 2004 | 03:47 PM
eg6sir-s's Avatar
Default Re: (bigbacon2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigbacon2 &raquo;</TD></TR><TR><TD CLASS="quote">i am using a 97 usdm ls and the ecu and everything is the right one and everything else is hooked up for smog. the only thing i have heard tho is that it will not pass because it is an obdII motor going into an obdI. i heard there is no way to pass an obdII motor off in an ObdI car. any comments would help thanks</TD></TR></TABLE>
your car will pass as long as all the smog equipment and uspec ecu regardless what chassis its in.
Trouble
Mar 16, 2008 11:09 PM
mike03,95civic
Aug 17, 2007 05:38 PM
92integraVTECgsr
Dec 17, 2006 12:03 PM
Honda_SiR-G
Jun 5, 2005 12:08 AM
bigbacon2
10
Sep 1, 2004 03:25 PM
